Eneloop AAA BK-4MCCE 750mAh (White) 2019
Official specifications:
Nominal voltage: 1.2V
Minimum capacity: 750mAh
Low self discharge: 70% capacity left after 10 years
Cycle life: 2100 cycles.
Maximum temperature raise at different discharge currents: 1A:+2,3°C, 2A:+5,3°C, 3A:+7,9°C, 5A:+12,1°C
The newest generation Eneloop AAA cells.
The two cells tracks nicely and discharge characteristic as expected for NiMH.
Internal resistance calculated by pulsing 0.5A on/off during a full discharge.
Conclusion
There is not much to say about eneloop batteries, they work and they last a long time.
Notes and links
I am replacing my NiMH charger test batteries, they are from 2016 and some of them has a fairly high internal resistance. Some of the bad chargers I have tested have probably increased the deterioration rate of them.
The extra data in this review is not something I will do in other reviews, except maybe a few IR curves may show up.
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
