I hate the green in lights. Blue I can handle but green makes me put the light in a drawer. In this light I see no green whatsoever, I have used it for a while now as a backup on my keys, even though it’s a backup I use it a lot as my keys are generally easier to grab than the light in my belt holster.
I love c01s, the color and tint is perfect, no greenish crap.
The current at high mode is 2.2A, and at low modde is 0.022A, so that is 100 times difference. I wish it has “middle” mode at around 30 lumen(0.2A), then it would be a perfect keychain light
Are you sure you are getting 2,2A?
At 2,2A on high mode, you’d kill the AAA in less than 25 min.
i double checked it, yup, it runs 2.2A and 0.022A
Nice meter
It can do RMS current even at the high frequency that boost driver might be running?
I did not read through the entire thread, but I saw the light is advertised 100 lumens for well over an hour on a AAA battery. I don’t personally believe that, curious if anyone has tested it? I see above someone measured 2.3A on high, definitely not getting over an hour, even with a lithium primary. Is the 100 lumens accurate?
No, never over an hour runtime. It puts out 90 lumen of high CRI which requires almost 400mA through the led, so that little boost driver is doing its best, 2.3A sounds a bit high (on the full battery I assume) but that must be a not so efficient driver then. Must be 20 minutes, anyone doing an actual runtime test? (maybe me but not this week).
The BLF C01S silver color is available now
I just bought 3 of them
Thank you!
Ordered
Order placed
Gone just when I logged into AE
I just logged into AE and can see: (92 pieces available)
Ah, wrong language/currency. Again, I felt for it. Thanks.
bought a few, they look good
I’m going to get in trouble, but I’ll be getting one :3
Any discounts available for this?
Oh finally a low-high C01S.
Will order it.
No discount available probably. 9,99$US is already very low.
Have not seen discounts for the C01S yet, would be nice to have one for the BLF-version.
Barry?
Ordered one
