I thought of the MC3000 but from what I read their is not really a working just put battery in and let it charge option. My mother who I support that lives with me probably would not be able to just plug in AA or AAA batteries and have them charge with no effort. I love complex stuff as I am into computers big time and have setup my own HTPC using a Logitech Harmony Remote but for a charger I need to consider that my mother can just insert and it charges for her.
Even the protected ones?
I can’t imagine, how even the unprotected fits, as not all the pins can be moved to the end of the charger. At least on my MC3000.
I would not rule out an MC3000 because you are worried about a non tech person using it. Just assign the charge programs for the batteries they are going to charge to one of the short cut keys. Then it becomes a two key press operation to charge the batteries. The current firmware allows for 8 short cut key assignments. I made up a cheat sheet for my wife and she uses the chargers all the time. I think by now she has the key press sequence memorized. I set them up to be up+1 is AAA white, up+2 is AA white and up+3 is AA black. Also unprotected 21700’s fit fine. I don’t own any protected 21700, however for sure I would not count on them fitting.
Is there a good video or review that explains the MC3000? I checked out Youtube but all useless they mention Modes: Dummy; Simple; Advanced but do not explain what any of these modes are. I keep seeing mention of a cheat cheat but I don’t even understand why a cheat sheet is needed just how complex is this unit?
The user guide has its flaws also. I will have take notes when to click, when to press (long click) a button …
In short:
Dummy mode: only NiMH and LiIon. You can set up in the settings the charging properties, after that you show in the batteries, and it will charge them.
Simple and Advanced: you can create programs to charge the batteries: chemistry, charging/discharging current, etc. Simple means you can change less settings. In this mode, you put in your batteries, select the program you like per channel, and press start to charge.
The difficult part is to find the settings for the programs you need. After you set up the programs, it is almost dead simple to use it.
Wow… if they have BT capability why don’t they have a config dump and just have default configs users can download that support all types? Seems they are wasting the capabilities of this unit.
The BT is a joke. You just get an animation, instead of a visualisation how much you battery charged. Let alone, that sometimes you can’t even connect to the charger.
Maybe, I will take a closer look on that app, but it is not the best. Same for the windows program. I use the DataExplorer instead, to monitor, what happens in the charger.
This is a very capable charger, but the user interface in the charger, through BT or usb is a joke sometimes.
Ok MC3000 is out my mother is 82 years old and to press more then one button to start charging is too much… Especially if it’s so expensive and they have not improved on the UI or set default battery charging.
So focusing on the main 3 of my requirements the others were just a plus and not absolutely necessary.
LiitoKala Lii-500
Miboxer C8 or C4-12
Opus BT - C3100 V2.2
Xtar Dragon VP4 Plus
These are all chargers I can purchase in US either from BangGood or Amazon. I want to purchase from US either Amazon or a site that uses Paypal for payment. So if the MC3000 or Dragon did not exist what charger would you order that has the most of the features for the money?
Both are great chargers, and if the MC3000 weren’t available, I’d go with either of them, and probably the A4, since it has a more intuitive multi-button UI and support for LiFePO4.
1. “Upgrade” Miboxer C4-12 with Li 4.35 and LiFePO4 ( The old version has a bunch of children’s sores with charging slots and springs )
2. Miboxer C8
3. Xtar Dragon VP4 Plus
Buy only new version - “Upgrade C4-12” with two yellow button!!!
Old version have frequent problem with springs, dying third slot, not support: 21700 protected, LiFePO4, Li 4.35
Ok got it. BTW what is the difference in the C4 v3 and the C4-12 they both look exactly the same. Are they the same but maybe just a different numbering for Amazon as on Amazon I only find the C4 v3.
Get a analyzing charger for yourself and a cheap trustable charger for your mother. I hardly use my opus cause it’s a big noisy block, I replaced it with gryfalcon 88 for just charging my cells. Even though the gryfalcon has 8bays as opposed to 4 it still looks smaller and makes a lot let noise then my opus. A Littokala can be bought pretty cheap depending on the amount of bays.
What is the difference in an Analyzing charger? I thought they all did the same the C4-12 and Opus BT. But if that is not the case the only one that I see that qualifies in my price range, found in US would be the Opus BT-3100 V2.2 as I can get that on Amazon.
