Features:
Utilizes XP-L HD LED with a lifespan of 50,000 hours
Powered by one AA or one 14500 rechargeable Li-ion battery, 550 lumens max output
Only 90.6mm in length, 26g in weight, handy and compact, easy to carry
Two ways to select outputs: Tail switching or twist the head
Made of aircraft-grade aluminum alloy with anti-scratching type HAIII military grade hard-anodized finish
Double-side AR coated, tempered window resists impact and thermal shock, max 99% light transmission
Waterproof to IPX-8 standard
Package included:
1 x LUMINTOP Tool AA 550LM Portable LED Flashlight (Without Magnetic Tail)
1 x O-rings
1 x Lanyard
1 x English Manual
Features
Utilizes OSRAM LED with 50,000 hours lifetime
2 modes with a max 130 lumens output and an up to 7.5 hours runtime
Micro USB rechargeable with built-in charging indicator
built-in 3.7V/80mAh 10180 Li-ion battery, fully charge within 57 minutes
Tiny and light-weight design, 41.5mm in length and 11.8g in weight
Three colors optional, black, silver and pink
TIR optical lens creates a soft and balance beam
Glow-in-the-dark O-ring easily locates the light in the dark
Simplify twisty switch, easy operation within one hand control
Make of aircraft-grade aluminum alloy with military grade type III HA matt finish
IP68 rated dust and waterproof protection, impact resistance to 1.5 meters
Size: 41.5*14mm, Net weight: 11.8g
2 years free repair, limited lifetime warranty
Package Included:
1 x EDC Pico Keychain Light
1 x 10180 rechargeable li-ion battery (bult-in can not remove)
1 x Charging cable
2 x O-ring
1 x Keychain
1 x User manual
Package included:
1 x New Arrival Rofis R4 Flashlight
1 x 21700 Battery
please use the form below to get the deal info - Member can check in my deals list
https://docs.google.com/forms/d/e/1FAIpQLSeS3yajJeMuRKSeYWOjPzUHc3-AYRrwEEj-lyCEJHt5c6eAQw/viewform?embedded=true
Features:
· Astrolux C8 is redesigned with BLF A6 driver which is more durable, more powerful, and more functional.
· Utilizes a XP-L HI LED
· High efficiency constant current circuit enables maximum output up to 1300 lumens
· Driven by one 18650 battery for maximum runtime up to 300 hours
· Boasts a peak beam intensity of 102000cd and a throw distance of up to 639 meters
· Hidden battery check
· Direct access to ultra-low and turbo output
· User selectable "4 or 7 evenly-spaced modes".(Moon to High)
· User selectable mode memory (always starts on Moon without mode memory but easily reverses to Turbo with a click)
· Fast PWM for lower regulated modes
· Toughened ultra-clear mineral glass with anti-reflective coating
· Constructed from aerospace grade aluminum alloy
· HAIII military grade hard-anodized
· Waterproof in accordance with IPX-8 (2 meters submersible)
· Impact resistant to 1.5 meters
· Tail stand capability
Package included:
1 x Astrolux C8 XP-L 1300Lumens 7/4modes EDC LED Flashlight
1 x Lanyard
1 x O-ring
Introduction:
Astrolux TP01 Tactical Pen is not only an exquisite writing instrument, but it’s also designed to be used in tactical situations.
The integration of the pen body is a unique design that is still rare on the market.
The tactical pen can be used with the 424 J2 Gel Pen to complete every great writing.
The refill can be freely removed and replaced.
424 J2 Gel Pen are durable, common and easy to buy.
Astrolux TP01 Tactical Pen is strong enough to handle any emergency, self-protection, or tactical challenge.
The body of the pen is made of aircraft-grade aluminum alloy, or a higher hardness titanium alloy or stainless steel, making it powerful enough.
Hi Martin,
For those of us that could not participate in their release, do you expect to offer a code to the group for the two new Imalent lights in the near future?
