Martin, looks nice. But… fountain pen or GTFO
I wish they could make good looking titanium (without funky colored pattern) mechanical pencils 0.5 / 0.9 / 2.0 mm
Hello my dear friends!
i got the groupbuy for 2 new Lumintop flashlights:
(the links in the pictures and text below take you to the shop for additional info)
LUMINTOP Tool AA 2.0
color: Titanium Gray / Panda White
XP-L HD 550LM 3Modes
AA/14500 Mini LED Keychain Light
Features:
Utilizes XP-L HD LED with a lifespan of 50,000 hours
Powered by one AA or one 14500 rechargeable Li-ion battery, 550 lumens max output
Only 90.6mm in length, 26g in weight, handy and compact, easy to carry
Two ways to select outputs: Tail switching or twist the head
Made of aircraft-grade aluminum alloy with anti-scratching type HAIII military grade hard-anodized finish
Double-side AR coated, tempered window resists impact and thermal shock, max 99% light transmission
Waterproof to IPX-8 standard
Package included:
1 x LUMINTOP Tool AA 550LM Portable LED Flashlight (Without Magnetic Tail)
1 x O-rings
1 x Lanyard
1 x English Manual
LUMINTOP EDC Pico
130LM USB Rechargeable Super Mini EDC Flashlight
Features
Utilizes OSRAM LED with 50,000 hours lifetime
2 modes with a max 130 lumens output and an up to 7.5 hours runtime
Micro USB rechargeable with built-in charging indicator
built-in 3.7V/80mAh 10180 Li-ion battery, fully charge within 57 minutes
Tiny and light-weight design, 41.5mm in length and 11.8g in weight
Three colors optional, black, silver and pink
TIR optical lens creates a soft and balance beam
Glow-in-the-dark O-ring easily locates the light in the dark
Simplify twisty switch, easy operation within one hand control
Make of aircraft-grade aluminum alloy with military grade type III HA matt finish
IP68 rated dust and waterproof protection, impact resistance to 1.5 meters
Size: 41.5*14mm, Net weight: 11.8g
2 years free repair, limited lifetime warranty
Package Included:
1 x EDC Pico Keychain Light
1 x 10180 rechargeable li-ion battery (bult-in can not remove)
1 x Charging cable
2 x O-ring
1 x Keychain
1 x User manual
check the member deal list or use the form below to get the deal!
How is the UI like on this latest Tool?
Oh no, why would they make the 10180 Pico battery non-removable?
Is there over discharge protection in case it gets turned on while in your pocket?
The 10180 is not available in a protected version so it’s easy to ruin these little batteries.
the tool is a Tool AA 2.0
and I saw on Facebook they announced it as panda white and black - asked for confirmation.
confirmed itx a Tool AA 2.0
color is called "Panda White and Black"
link has changed too!
Hello my dear friend!
Here is the groupbuy for thew new:
(links in pictures take you to the shop for detailed Productinfo)
ROFIS R4
XHP50.2 2300 lumens
6Modes Head Rotation Magnetic Charging
21700 LED Flashlight
Specifications:
Product name: | ROFIS R4 XHP50.2 6Modes 2300 lumens Flashlight |
Brand: | ROFIS |
Model: | R4 |
Emitter Type: | XHP50.2 |
Peak Beam Intensity: | 10413cd |
Max Output: | 2300 lumens |
Range: | 204M |
Mode: | Low, Mid, High, Turbo, Strobe, SOS |
Lumens: | 20lm, 240lm, 900-600lm, 2300-900-600lm, 1200lm, 900lm |
Battery Configurations: | 21700 Lithium-ion(Included) |
Impact Resistant | 1m |
Waterproof: | IPX-8 Waterproof |
Carrying Strap: | Clip |
Color: | Black |
Weight: | 97g |
Size: | 134mm x 28.5mm (Length x Body) |
Package included:
1 x New Arrival Rofis R4 Flashlight
1 x 21700 Battery
please use the form below to get the deal info - Member can check in my deals list
https://docs.google.com/forms/d/e/1FAIpQLSeS3yajJeMuRKSeYWOjPzUHc3-AYRrwEEj-lyCEJHt5c6eAQw/viewform?embedded=true
Wow, do you know if the R4 is using the new 3v 50.2?
no - sorry
buit i try to find out
banggood listed the
FIREFLIES E01
LUMINUS SST40W N5 5700K 2300LM 21700/18650 LED FLASHLIGHT
for US$29.99 using my Code MFE01
you can find all deals in my list: M4D M4X deals
Astrolux released a new light and their first tactical pen today!
and M4dM4X.com fans get the lowest deal again!
(the links in the pictures and text take you to the shop for additional info!)
Astrolux C8 Silver US$ 17.99
XP-L HI Long Shot 1300Lumens
7/4modes with BLF A6 Driver
Tactical EDC LED Flashlight Searching Flashlight
Features:
· Astrolux C8 is redesigned with BLF A6 driver which is more durable, more powerful, and more functional.
· Utilizes a XP-L HI LED
· High efficiency constant current circuit enables maximum output up to 1300 lumens
· Driven by one 18650 battery for maximum runtime up to 300 hours
· Boasts a peak beam intensity of 102000cd and a throw distance of up to 639 meters
· Hidden battery check
· Direct access to ultra-low and turbo output
· User selectable "4 or 7 evenly-spaced modes".(Moon to High)
· User selectable mode memory (always starts on Moon without mode memory but easily reverses to Turbo with a click)
· Fast PWM for lower regulated modes
· Toughened ultra-clear mineral glass with anti-reflective coating
· Constructed from aerospace grade aluminum alloy
· HAIII military grade hard-anodized
· Waterproof in accordance with IPX-8 (2 meters submersible)
· Impact resistant to 1.5 meters
· Tail stand capability
Package included:
1 x Astrolux C8 XP-L 1300Lumens 7/4modes EDC LED Flashlight
1 x Lanyard
1 x O-ring
Astrolux C8 silver version Code: MAC8 price: US$ 17.99
and the all new:
Astrolux TP01 from US$16.99
Titanium Bolt Action EDC Survival Pen Tactical Pen
Introduction:
Astrolux TP01 Tactical Pen is not only an exquisite writing instrument, but it’s also designed to be used in tactical situations.
The integration of the pen body is a unique design that is still rare on the market.
The tactical pen can be used with the 424 J2 Gel Pen to complete every great writing.
The refill can be freely removed and replaced.
424 J2 Gel Pen are durable, common and easy to buy.
Astrolux TP01 Tactical Pen is strong enough to handle any emergency, self-protection, or tactical challenge.
The body of the pen is made of aircraft-grade aluminum alloy, or a higher hardness titanium alloy or stainless steel, making it powerful enough.
Specification:
Brand: ASTROLUX
Model: TP01
Total Length: 119mm
Diameter: 12mm
Material & Weight (With Pen refile):
- Titanium Alloy: 25g
- Stainless Steel: 55g
- Aluminum Alloy: 35g
Adapted Pen refill: 424 J2 Gel Pen
Pen refill diameter: 0.5mm
Model / color | Code | price |
TP01 Titanium WAVE / LIGHTNING | MTP01 | 50.59 |
TP01 Titanium primary | MTP01 | 30.29 |
TP01 Stainless Steel COLOR | MTP01 | 28.19 |
TP01 Stainless Steel primary | MTP01 | 26.09 |
TP01 Alloy Blue / RED / Yellow | MTP01 | 16.99 |
I just placed a pre order for a Ti Pen, great deal with your code, many thanks
i got some very nice deals for you:
NEW ARRIVAL
Sofirn SF10, SF11, SF32 UV flashlights and 8 slot/16 slot chargers are available on AMZ US. We provide some codes for you from 17th, May to 25th, May.
SF32 UV kit: $24.99, only $21.24 after code (SOFIRNSF32UV)
SF10 without battery: $12.99, only $11.04 after code (SOFIRNSF10)
SF11 without battery: $23.99, only $20.39 after code (SOFIRNSF11)
8 slot charger: $9.99, only $8.49 after code (SOFIRN8SLOT)
16 slot charger: $20.99, only $17.84 after code (SOFIRN16SLOT)
COB headlamp: $12.99, only $11.04 after code (COBHEADLAMP)
Mini Keychain light: $9.99, only $8.49 after code (COBMINILIGHT)
Flashlight Holster: small-$5.99, medium-$6.99, large-$7.99
Beam Diffuser: small-$4.99, medium-$5.99, large-$7.99
C8A/C8T Remote Switch: $6.59
BLF Q8 Switch Assembly: $4.99
BLF Q8 Driver Chip: $9.99
BLF Q8 Copper DTP MCPCB: $6.99
BLF Q8 Reflector: $8.99
The BLF Q8 reflector,above, sold my amzn,is different from the original one?
There should be only one version.
got some Amazon deals for you:
Amazon.DE
Artikel: SP70 kit |
Rabatt: 30% off |
Preis: € 69.99 |
SP70 without battery | ~33% off | € 50,- |
Code bitte per mail anfragen (nur wenige verfügbar!)
Amazon.COM
Sofirn SP36 BLF Anduril Powerful Flashlight, 4 LH351D LED 5000K 90 CRI, USB C Rechargeable
only US$ 49.99
Hi Martin,
For those of us that could not participate in their release, do you expect to offer a code to the group for the two new Imalent lights in the near future?
Imalent is very strict about speaking in public about codes
but you can read my signature ;)
