Also interested in this since I have a L4P all ready to go waiting for a FW3A, lol.
mixglo T1.5x3x9 1.5x3x9mm rectangular tritium vial
1.5mm (Thickness) x 3mm (Width) x 9mm (Length) rectangular tritium vial, green, ice blue, red only
There’s not much difference, I had no problem but I have used a very slightly thinner GITD O-ring, I’m sure the stock one would be fine, a little extra pressure on the MCPCB which is good.
Stock MCPCB = 20mm x 1.45mm, Noctigon = 20mm x 1.72mm.
Nice, in that case the LED4Power one is actually 1.5mm so no issues. Good to see it should drop in most of the good triple boards out there
Do you know if the stock springs are steel, bronze or copper?
No idea, haven’t seen anything about them. Could be silvery coated steel or something?
I did get a slight boost by bypassing them.
Are they magnetic? That would narrow it down
Didn’t even think
Not magnetic.
Great stuff, as always. What would be the best size kapton tape to buy for this?
I have 30mm wide kapton tape, two strips of this will leave a gap of approx 2.0464mm, I cut thinner strips to fill this but it should be fine without.
Thanks!
Is anyone doing trit tail switches/caps?
Try to convince DrafterDan to make some for sale :innocent:
I dropped a PM to Neal about FW3A Trit tail caps… he will see if Lumintop is interested in making them?
Very impressive CRX! I like your tailcap tritium design.
Cool, might be a great seller, will probably need a redesigned rubber boot too :+1:
Thanks mate, yeah it was about the only way I could do it without machines and retain most of the original machined button look.
This is why I was so dismayed when that wabbit appeared on the final prototype!
Right on, he has Glo Caps …… but Trits are waaaaaaay Cooler! Been eyeing the 1.5x3x9mm retangular trits……
Funny, I’ve been looking at a 4mm x 1.3mm x 7mm rectangular green vial that I can get over here.
It would completely cover the tail switch hole but I also like it as is with the variable brightness due to the GITD backing the trit as I have it now. Decisions decisions…
From the diagram I can see you in 8x7135 mode, get 3 times sustainable output, 900 lm, compared to the original FW3A 300lm. How do you explain this enormous improvement? How is it possible?
Bypassed springs, thicker LED wires, cleaned & tweaked contacts, Noctigon MCPCB, better thermal paste, the light set to 65°C thermal limit, hand cooled & moving around, not standing alone untouched.
I have working mans hands so can take some abuse
Bearing in mind my sphere is not calibrated the output is close to what others have given for that level.
3x XP-L HI should give around that OTF lumens at 3A.
You may be referring to the stock light set up to 45°C thermal limit?
The thermal limit setting and cooling are factors that will determine the sustained output.
A single XP-L HI v2 running at 1A /65°C should give around 400lm.
