Recommendations for a full featured easy to use charger
45 posts / 0 new
EcuBebge
Last seen: 2 months 1 day ago
Greetings to the forum, as this is my first official post since joining a few months ago.
My introduction to LED lights was an Olight S1R, and up until very recently I’ve almost exclusively used lights with built in charging.
However, upon discovering BLF and learning more about what kind of lights are available, I’ve begun to expand my collection to include lights that require a separate charger. I’ve picked up a couple Astrolux lights, a BLF A6, I was able to get on the interest list and pick up 2 FW3As, and I have a couple Emisars enroute.
All that said, I’m in the market for a charger with at least 4 bays, charging primarily 18650s, but capable of charging a variety of sizes (26650 will be my largest cell currently, smallest 10440)
I’d like to stay in the $30-$50 range, but I’d pay a little more for something highly recommended.
As far as features, I don’t know enough about chargers to know what I do or don’t need. So I’m hoping someone will point out the most important features I should look for.
Any thoughts or suggestions would be greatly appreciated.
Pete7874
Pete7874's picture
Last seen: 2 hours 36 min ago
I would take a look at the latest version of miboxer c4-12.
Lightbringer
Lightbringer's picture
Last seen: 1 hour 34 min ago
Each one has its pluses and minuses. No one has it all. Yeah, read that again, let it sink in. You’ll go crazy trying to find The One™, so don’t bother.
Hence, I have an almighty Miboxer (hey, it says so right on the box), a regular mighty Opus, a Zanflare, and a Nitecore. All 4-bay chargers, not even counting the 1- and 2-bay LKs.
Most of the time I use my mighty Opus, but I have it on a cellphone/tablet stand oriented vertically to let hot air naturally waft its way up’n‘out, as it gets heat-stroke pretty easily. And I don’t want the fan buzzing like an angry bumblebee all night long.
It seems to be the most flexible, so if you want to start with one, I’d go with the Opus (BC-3100 or whatever).
Pete7874
Pete7874's picture
LOL! That was funny.
Deputy Dog
Deputy Dog's picture
Last seen: 14 hours 55 min ago
I like my XTAR VC4
Lightbringer
I’m glad someone caught it. Most times… >zing!<. Flat Stare
BlueSwordM
BlueSwordM's picture
Last seen: 2 days 8 hours ago
Folomov A4:
https://www.illumn.com/batteries-chargers-and-powerpax-carriers/chargers...
Full of nice features.
Can charge cells quickly, can charge all chemistries.
flydiver
Last seen: 9 hours 2 min ago
What Lightbringer said.
I’d add the Lii-500 and Zanflare C4, the C4 being my go to charger for most things, but the Opus has more features and power.
Internal resistance is useless on the Lii, and seems better than the Opus on the C4.
Nev
Last seen: 11 months 1 week ago
Deputy Dog wrote:
I like my XTAR VC4
Have you checked your cells just after charging is finished?
When My VC4 finish charging the cells are 4.22
azj
Last seen: 4 days 1 hour ago
In fact, you could say, the more pluses and minuses, the more batteries it supports… Big Smile
+1 for the MiBoxer, it’s kinda my “goto”
Mishanchik
Mishanchik's picture
I would recommend:
1. Full automatic – XTAR VC4S
2. With manual settings – Miboxer С4 Plus.
koti
Last seen: 1 year 1 month ago
I’vce been using the Miboxer C8 for about a month now, so far so good. It’s idiotproof, its got only 2 buttons, it does everything for you out of the box, you can easilly configure current if you want, it seems to work like it should whetehr its 10180 or 26650 or Eneloop AA’s. I had tons of chargers over the years, this one seems fine.
Melez
Last seen: 1 day 7 hours ago
Does that Miboxer С4 Plus have settings that you could use to charge to 4.10v instead of 4.20v?
BlueSwordM
No.
flydiver
Nothing under $50 is going to have adjustable termination voltage. A few chargers will do multiple chemistries so you can charge under and over 4.2v by setting that.
There is a hidden switch on the underside of the Opus you can access if you cut a hole in the case bottom. That will allow you to change that one.
teacher
teacher's picture
“Recommendations for a full featured easy to use charger”….
Liitokala Lii-500
  • Economical
  • Easy to use
  • Measures discharge capacity
  • Does a good job.
EcuBebge
I actually ordered that unit with one of Mad Max’s coupon codes via banggood, but it arrived with a busted lcd.
I just received my refund, so I figured I’d see what everyone had to say prior to placing another order.
teacher
teacher's picture
Busted LCD… that’s bad luck. Sad
Yeah I like the Lii-500. I have the Opus that does the same stuff the Lii-500 does… but I like the Liitokala much better.
Better luck on your next one… whichever you get, hope you receive it in one piece. Thumbs Up
EcuBebge
Thanks everyone for the thoughts and suggestions.
Based on your recommendations, and further reviews of the chargers you’ve recommended, I’ve decided to go with the MiBOXER C4 or some variation thereof.
Pete7874
Pete7874's picture
Just keep in mind, the C4 cannot perform discharge capacity test. Not sure if that was one of your requirements or not.
Lightbringer
Pete7874 wrote:
Just keep in mind, the C4 cannont perform discharge capacity test. Not sure if that was one of your requirements or not.
That to me would’ve knocked it out of the running immediately. I like my (Nitecore) i4, but that it can’t do said tests means I rarely use it anymore. Sad
hiuintahs
I needed a charger to do the longer 21700 cells and I went with the Miboxer C4-Upgrade. One amp for all 4 bays, or 1.5A for two bays is adequate for me. I’ve been happy with it. I like that it has the option for 12v with a standard 5.5 × 2.5mm jack or can plug in an AC cord. The Miboxer Upgrade C4-12 only has 12v input which is fine by me too. I use a 12v power supply that can source more current than most wall transformers. Nice to be able to use in the car.
For discharge capacity testing, I have a dedicated capacity tester (a ZHIYU) and didn’t need it built into the charger. (but seldom find a need to use it anyway). The new Miboxer Upgrade C4-12 (now has two yellow buttons) wasn’t available when I got my C4-Upgrade. Still waiting for it to become available on Amazon.
WalkIntoTheLight
Nev wrote:
Deputy Dog wrote:
I like my XTAR VC4
Have you checked your cells just after charging is finished? When My VC4 finish charging the cells are 4.22
That’s within spec, which is 4.15v – 4.25v.
All my chargers have slightly different termination voltages. I prefer the ones that terminate a little under 4.20v, but some terminate higher. It won’t damage the cells, but you’ll get maybe 10% less cycles from them. You’ll also get a bit more capacity out of them, though probably only 1% – 2%.
My Xtar X4 terminates around 4.18v. So, I don’t think Xtar is designing chargers to terminate high. It’s just the random variance in the chips that all companies use.
I think my next charger will be the SkyRC MC3000, because you can set the termination voltage to whatever you want.
Lightbringer
Hmm, wondering if anyone’d want to try one of these for custom termination-voltage settings… LOL
http://budgetlightforum.com/node/66901
It actually looks pretty good for that, as long as it’s consistent.
VernonDent
Last seen: 7 months 2 weeks ago
Apologies for hijacking the thread…
This C4-12 version 2. Does anyone have a link on amazon (I’m in the USA) for this charger?
What about this:
https://www.amazon.com/Battery-Charger-Rechargeable-Batteries-Universal/...
From my cursory search, seems the C8 is not a discharge unit, only a charge unit? Is the C4-12 V2 an “analyzer” the charger like the opus 3100?
Pete7874
Pete7874's picture
As was mentioned a few posts back, it’s not on Amazon yet.
Correct.
No.
Nev
WalkIntoTheLight wrote:
Nev wrote:
Deputy Dog wrote:
I like my XTAR VC4
I use the sky rc now for most of my charging needs.
Agro
Agro's picture
Last seen: 1 hour 56 min ago
At BLF we have our own custom lights…but no a custom charger.
I agree there is not a single one that could do it all.
I would gladly buy such product. Maybe we could talk with manufacturers to produce it?…
teacher
teacher's picture
That is an appealing idea Agro. Thumbs Up I would be in for one too.
Besides finding a manufactor to do it, the biggest problem I see is us at BLF agreeing on which features to include on it.
BlueSwordM
There is only one feature we SHOULD include:
*Being able to change the end charge voltage from 3,9-4,2V for lithium-ion cells. *
That would make for the absolute best charger.
Nev
BLF SKYRC MC3000.
