Emisar D18 introduction
They’ll never know what hit ’em!
Also, I’ve been to the Eagle and Child. Talk about kismet.
i bought like a month ago a sp36 (regular version) for having my first “soda can style” flashlight and havent in my hands yet. Now i will like to get this emisar d18. Do they even compare in brigthness and candela? or they are two completly worlds apart?
That’s what I like to hear. :slight_smile:
SP36 is taller, narrower, and much more throwy. Also heats up less so it stays up at high levels longer. Has a built-in charger. Costs significantly less.
D18 is smaller overall, makes a lot more light, comes in much better tints, has a much nicer-looking beam, and is generally higher quality. Also more mod-friendly.
They’re both good; it just depends on what you’re looking for.
Thanks TK, you gave me an idea of the differences and usages. I will have to pick either sell the sp36 and get this d18 or keep it and dont buy the d18. If it was your very first “soda can” and dont have more than a zebralight sc63 and a olight s2 baton, which would you choose?
Anyone else’s bezel stick out slightly? On one side of my light for about an inch or 2 the edge of the bezel sticks out enough to catch your finger on the sharp underside.
It also seems like the lens gets some slight wear on it from the optics rubbing against it when the bezel is fully tightened.
Just checked mine, and also found that edge of bezel you speak of. I hadn’t noticed it until you mentioned it. I know there has been mention of the lanyard hole placement, I find it to be in the perfect spot. I actually use both pocket clips and lanyards on my lights, one problem I have found is that the alignments don’t very often match thumb placement to the button. The D18 has perfect lanyard to thumb alignment for the way I carry.
Has anyone tested the D18 with Sanyo NCR18650GA? I know it will have less initial output, but it shouldn’t heat up as fast and thereby hold it’s output longer.
Interesting, mine is positioned nicely for left hand use. If only I were left handed…
I am 99% positive they are Lisa2 optics, though I can’t figure out which specific model the “standard” throwy optic is. One of them out of my D18 measures 9.9mm diameter by 7.0mm height, not including pins.
The wide optic is, I believe, the 10997 model, or perhaps 11429. I ordered 6 from Hank to mix a little more flood in, but there is no part number or anything.
I ordered 2 different Lisa2 models from Arrow I’ll see if I can tell which the stock one is
From left to right:
  • Stock optic
  • FP13028_LISA2-M-PIN (~20 degree)
  • FP13025_LISA2-W-PIN (~35 degree)
The two I ordered fit 219B with room to spare but still no LH351D. I suspect an XP-L HI, though not supported by ANY Lisa optics, would do better with this optic versus the stock one. I will try to compare a full set of stock optics VS a full set of FP13028_LISA2-M-PIN. The fit looks better even for the SST-20 to be honest…
Yes, and they powered the light without issue. I’ve been buying the flattops from Zebralight for years and they worked because the top protrudes past the label.
This is not a good choice. The current consumption from each battery is 15A (in turbo). This is the voltage drop with this load compared to Samsung 30Q.
It seems a good choice for his requirements which is longer, but slightly lower turbo output which heats up slower. Plus it has extra capacity to run longer at lower levels. Maybe he wants this?
With GA’s, the load on each battery will probably be less than 15A each.
I don’t think GA’s will hurt anything as long as you don’t care about measuring the max turbo lumens.
Yes, I agree it’s not a good choice if I’m bench racing for lumens. I’m curious how much lower the output would be with the GA’s. I’d love to see an output graph of with the GA to see what is given up in Turbo (which I’d rarely use aside from wowing people) in exchange for longer runtime at lower levels.
If you aren’t wowing people with turbo then don’t worry about using a GA. In reality I think the light is capable of pulling 15A per cell like komeko says but in my testing my light is only hitting 10K lumens briefly with a 30Q. So 15A is pretty much the upper limit with a 30Q using this light.
Interesting, the flood optics I got from Hank look different than both of those. They seem to be somewhere in the neighborhood of ~60 degrees?
There were wider ones for sure but I got the narrowest two that would fit 219b LEDs
I did this for science but the results are so similar i’m not sure it’s helpful to anyone. The hotspot appears to be ever so slightly less defined and edge of spill slightly cleaner. I thought the efficiency might go up but it appears to produce more or less the same lumens with both optics. I still think XP-L HI might benefit from this larger LED opening but i’m only going to try 219B.
Datasheet has support for other small-ish die emitters: XPG2/3, 219B/C, Oslon Square, E21A, LH351B
OEM / FP13028_LISA2-M-PIN
