Has anyone tried an xhp50 3v in the micro yet?
I love this light, perfect for EDC on the belt.
Doesn’t make sense… You would have to find a 14500 that is able to deliver more than 8A to justify the XHP50 over the SST40
But then again, the 3V 50.2 can deliver far more lumens than the SST-40, soooooo, a top 14500 pushing a 3V 50.2 should give an interesting boost over the use of an SST-40, AND a sliced and diced 50.2 would be even more interesting!
Nothing back from Neal. I have chased him twice. I guess its Paypal dispute time.
I just noticed Vapcell released a 14500 650mah 7A button top battery 7A CDR, 13A max discharge current. Seems to be the best high drain 14500 available on the market. I previously bought their 14500 1000mah batteries, which is the best high capacity 14500 on the market, and I tested them to be legit specs.
Has anyone done any measurements with this battery on their GT Micro or with a similar high drain battery? I’m wondering if the new Vapcell will be able to manage 4.5A in this light. Thinking of buying one to put a White Flat in there.
My Vapcell 14500 looks identical to the high discharge Enercig.
They look identical. Apart from wrapping.
im having a problem with my micro, it was working fine and then i swapped in a sst-20 and the led was staying on all the time, i thought yeah some short somewhere maybe its the reflector but nah and then i was like well might be the led wires touching on the mcpcb or something so decided to remove the driver and replace the led wires but nah yeah still the led stays on. so i was like ok maybe the head is touching something so i took the whole driver out and powered it up and led still on always. so i dunno its beyond me at this point, any ideas would be great.
That is rather odd, generally that is a sign of a bad 7135 but it is strange that it only started happening after the LED swap. Generally excess heat or voltage would kill the 7135.
i tried to get the 2 boards apart but it seemed to difficult, i might try again and replace the 7135. would a short cause that kind of damage to the 7135 chip if i did something unknowingly? it seems to function normally during ramping and blinks where it would normally blink at the top of regulation, its got anduril.
A short could possibly damage the 7135 just not as common.
You will need to de-solder the brass bars that hold the PCB’s together in order to take them apart. You will need a hot air gun to do both of them at the same time I am pretty sure.
Worst case you might be able to get a replacement driver from lumintop.
What’s the best 14500 for a Osram 1mm^2 White Flat GT Micro?
Where did you find the new 14500? I also have the 1000mAh one and the efest purple
look what i saw on mad max fb page… gt nano is coming soon
I got the GT nano prototype the other day. The first design was not giving the output I expected so made a few changes that should improve things.
Trying to pick the LED for this light actually. The white flat is interesting but sourcing them can be hard and only CW tint.
What is the best version of the white flat model number wise to have them look for it? I loose track of all those flat LED model numbers.
KW CSLNM1-TG.
That is the 3030-size small die (1mm2) version that you want for a mini-thrower like this.
Mind that this led needs a different than usual centerpiece to fit the 3030-size led.
It is at least available at all the “western” sellers Mouser, Digikey, RS. And our led4power.com of course.
Great, thanks for that. I have passed it on so we will see what they come up with.
I just tested the GT Micro with the known best 14500 cells on the market. The new Shockli 14500 1000 mah matches the output of the previous king of high current 14500, Windyfire 600mah but with much more capacity. Very impressive. The output with these cells make this light almost as bright as the GT Mini and D1S. The Shockli also beats Sanyo UR14500P by a large margin, which was the previous best overall 14500.
The GT Micro just became much more interesting.
