I bought 4 of these (Drivers only) from the convoy store and the first one I used in a C8 did not work as advertised. Mine has 2 modes. mode 1-L,M,H then mode 2- L,M,H and strobe. I have sent a message to Simon with no response. I can also add that it takes 5 half presses to switch modes. Thought maybe he sent the wrong drivers to me. Even went back to double check my order because I know there are 2 versions of this driver. Weird.
Does anybody have an idea what other firmwares will work with that driver?
Had one of these arrive yesterday.
The UI is a bit strange. First full click took me to what appeared to be full power. Two half clicks took it down to a lower level. Nothing too bad there.
Five half clicks got me to the bit where it ramps through the power levels. It’s a bit odd and needs getting used to.
As usual I can’t criticise the quality, everything is spot on.
On high I’m getting 6.9A at the tail from a Samsung 30Q which seems pretty good, and it’s bright, considerably brighter than my C8 with XPL HI and Fet.
I might get a BLF A6 driver from Banggood and drop that into it assuming the SST-40 won’t burn out using a Fet.(?) The UI would be a bit more user friendly.
I reckon that 6.9 amps should be giving me over 2000 lumens. Pretty good for a stock C8. I might even leave the current driver in place, I like going straight to full power.
Is the ramping level stored in the first and second mode, or is the first mode always high? The diagram is confusing.
I am yet to finish a C8S build with one of these you are speaking of. Despite weird the UI features two ramping modes, 1st and 2nd. The third is the multiple selectable functions one. I plan on setting it as follows:
- Single tap: ramping set somewhere in the middle, for a nice and practical amount of output versus current consumption.
- Double tap: ramping set at 100%.
- Triple tap: 1%.
Thu, 05/16/2019 - 01:24
So can this driver be reflashed ?
Can these C8+ be fitted with an ON/OFF 100% sw.
Nothing else?.
Or. As I have in a SolarStorm SC02. (18650 cell)
Side sw.
1 and hold. is ramping, Set where you like and it’ll stay there. with a single click… to 60%ish.
Then it’s.
1 click for that setting.
second click is 100%.
The perfect switch for a no nonsense torch.
Get rid of all the other settings, OR don’t have,
IN THAT torch.
Just have fancy switches in multiple others
as we all do.
And I’m just a starter novice at collecting torches.
I haven’t checked this personally, but from the diagram it would appear to be the case.
Just got my driver for my s2+ triple xpl hi. Loved the driver so far
the first 2 mode is ramp programmable.
while the 3rd mode is a special group
but there is no memory in the mode cycle so it always go mode 1 mode 2 mode 3
you can set your first and second mode brightness to your liking by 5 taps when you’re on the mode.
while the 3rd group you can only choose a few options listed on the mode lists
Just tried a brand new, 30Q and got 7.1A at the tail. This could end up being my favourite C8
My C8+ SST40 with ramping driver arrived a little while ago and I’m very pleased with this light. Firmware seemed confusing according to the diagram but in real life it’s a fantastic firmware.
I measured 5.9A on 100% brightness with an LG HG4
It seems the reverse clicky switch supplied is the same used in other Convoy models (S2, S2+ etc). What are people’s opinions/experiences on the lifetime of this switch with 6 amps going across it? I couldn’t find any info on what the switch is rated for.
Omten 1288 switches eggmang, also known as “small Omten”. They're rated for 1.5A or so. I have some in service doing nice at up to 10A. When going really high current with them it is advisable to bypass the spring attached to them, namely if in direct contact. Their housing is made with a soft plastic which readily deforms with heat, this means you have to be pretty quick and careful when soldering over their terminals. Every time I solder one I verify test its resistance with my precision power supply and multimeter, a brand new or undamaged unit features 4mΩ of resistance or very little more.
I really find no good reason to make a switch with such a @#$% plastic. Pity.
Thanks Barkuti
From Convoy the driver and tailcap springs came with a bypass wire already soldered which was nice. I tested one of these springs once at 16 amps without the bypass wire and the spring itself got so hot that it could burn skin
I am considering removing the switch and short circuiting it so that the light turns on/off by tightening/loosening the tail cap. This should give even less resistance Is this a common practice among modders?
I also found these today, this will be useful for the driver end as it should have less resistance than the spring and bypass wire; (at 6 - 8 amps these small improvements should make a difference in light output) ;
Ordered one myself if anything, because the curiosity was killing me on the inside… :laughing: (emitter aside and all)
Here’s hope we’ll get them soon enough And also hope that we’ll get a 21700 version as well.
Wouldn’t the 21700 version be the m21a? There’s a groupbuy thread on it.
Does anybody have any review/opinion on the new(ish) Convoy 4-mode driver with thermal regulation ?
Is it legit thermal regulation, or just big dumb stepdowns when sensor goes over 55C? Does it work well ?
This is what I’ve written out for my customers so it’s easy to understand
Funtastic, I would particularly change the following:
For the 1st and 2nd modes, tap switch quickly 5 times to enter ramping mode adjustment. Ramping goes in increasing way and starts from the last set brightness level. If brightness was previously set at maximum ramping will start from the lowest setting. When ramping brightness is set and memorized by tapping or switching power. Ramping cycles a maximum of 3 times.
For the 3rd mode, tap switch quickly 5 times to enter a special config menu. The light will start blinking once per second, tap switch or switch power once the number of blinks matches the desired mode setting in the following list:
Suffice to say I like to be super explicit, 100% n00b proof. ;-)
Just came to my mind, I believe this driver could be improved. I find awkward having to double tap for 2nd ramping mode and triple tap for special. This is because this driver only has 3 modes, and I find myself setting the 3rd mode at 1% often. This awkwardness could be alleviated by cycling between 1st and 2nd modes, and double tapping for the 3rd special mode. No need for mode memory because both 1st and 2nd are fully adjustable ramping modes. All in all, less taps and easier to use.
Do you like? :CROWN:
That would be nice for general use. Most of my customers will be using this on a rifle so the current UI is perfect. Harder to switch to the wrong brightness using a pressure switch. If you release the pressure switch and quickly press again it’ll still remain in the 1st level
For the people in New Zealand that purchase from me they don’t usually know what Ramping is. This is the reason I worded the instructions that way. Tried to make it sound as simple as possible. I’ll give additional instructions after they’ve made the purchase.
Thanks for your input
