On my newest DS4 sst20 3000k version, I do not detect a difference between ceiling of the ramping and 2xclick turbo. Is this due to maxing out the led or it it a setting or electrical issue? I’ve tested IMRs that work perfectly in the xpl hi version. I’ve also tested it on the lux meter which showed possibly marginally lower output.
If you have stock D4S it doesn’t have Andúril firmware.
Meh. I’d rather they didn’t. Freeme does that sometimes in promotional materials, and it’s cringey. I don’t like marketing, and don’t like being treated as a brand instead of a person.
It’s quite possible that the ceiling-to-turbo transition could jump from one side of the hill to the other. The emitter’s output curve (lumen output according to amperage) has a peak, and going past that peak is unhealthy for the emitter. After the peak is reached, increasing the power actually decreases the lumens while dramatically increasing the heat. So if turbo makes the lumens go down, don’t use turbo. It could easily be shortening the life span of the emitters.
However, RampingIOS V3 is literally a copy of Anduril with some things removed and rearranged. The basic ramping functions are identical.
So ramp ceiling was visually the same as turbo so I changed to the stepped ramping. Now there is a pretty big difference between top step and the turbo. It was almost like the ramp was going all the way up to turbo. But I think you may be correct and turbo was jumping the current just over the curve. I think for this one I will keep it this way since it appears to adhere to expected operation. It’s nice to have options, thanks TK. Is the top step usually less output than the factory setting for the ramping ceiling?
I’m observing identical behaviour with my, just delivered, Emisar D18 with brand new button top VTC6 cells. In the default smooth ramped mode, there was no difference between the top of the ramp and turbo, while there is a noticeable difference in stepped mode. I prefer my ramp to go from moonlight to turbo, anyway, so I since configured it that way; but is there a chance these are coming delivered with the top of the smooth ramp being set to 150/150? Not a big deal. Just curious as I like to understand my lights’ configs as much as possible! Anduril is amazing, BTW!
The default config for D18 is:
- 1x7135 highest level: 50
- Nx7135 highest level: 100 (highest regulated level)
- Smooth ramp: 1 to 100
- Stepped ramp: 25 to 100 in 7 steps
- Thermal hard-drop level: 125
- Turbo: 150
So if it arrived with the ceiling set to turbo, the config has been changed. Maybe someone at the factory tested it.
Thanks TK!
That’s how my D18 is ,I actually prefer smooth ramp to ramp to turbo.
If you want the light to ramp all the way from the lowest level to full power, it’s fairly easy to set up…
- Turn the light on.
- Click 4 times.
- At the first prompt, click 1 time.
- At the second prompt, click 1 time.
Done!
Configuring it for a lower level takes longer. Like, to set the ceiling to level 100 of 150, it’s the same process… but the second prompt needs 51 clicks instead of just 1.
- Click 4 times.
Done!
Thanks TK , I will have a go ,i like the step ramp to go to ceiling then double click for turbo but I like to to ramp to turbo on smooth ramp , that’s how my d18 came , I would do it to the FW aswell.
Will it alter the step ramp as Well?
No. It only changes the ramp you were using before entering config mode.
Good , thankyou
thanks for all the info
is there a way to reset a D4 with Anduril to factory defaults?
I borrowed one and changed a lot of settings, and am getting ready to return it
fwiw, here are some pics and impressions:
I received this D4 on loan from a friend because I was curious about the UI. I have been EDCing a Jetbeam Rotary for several months now, and was curious about the electronic ramping of the D4. First impressions of the D4: cool ramping! fun playing with the stepped ramping, I like it better than the smooth ramp with a protected 16340 about 570 lumen max with an IMR 18350 about 1000 lumen max the light was stepping down in muggle mode, so I calibrated the thermal sensor it works very well a…
Does the fireflies e01 have a new version Andúril? Why am not able to program the maximum brightness as top of ramp? I tried 4 clicks with no response.
I’m pretty sure that while the flash light is on and in ramping mode you click four times then you will notice the light flutter and you push the button once and it allows you to access the lowest usable mode. Then it will flutter again and you push the button once and that allows you to access the highest usable mode.
Not on the fireflies e01. I have two of these lights and they both don’t flutter after 4 clicks.
I’m able to program my e07 though.
Gotcha. Sorry, I figured they were the same.
Fireflies asked me to make a new UI for the E01. It’s basically a stripped-down version of Anduril. The ramps are not configurable, and most of the blinky modes are gone. It has a police strobe and SOS instead of the Anduril strobes.
I have a problem with anduril. I set the ramp floor higher in the ramp cfg and want to set it down as low as possible again. How can I set it down? The diagram only shows how to set it higher.
- Click 4 times to start ramp config mode.
- At the first “buzz”, click 1 time.
- Wait until the config mode exits.
That’s all. That should set the floor to the lowest level.
