LED replacement bulbs for cars
I’m currently using this H4 bulb that has so called Lumileds Luxeon ZES for low beam and blazingly bright XHP50 for the high beams.
As an active cooling pair of front headlight bulbs they are pretty good in my case. Clean sharp cutoff from my big reflector and huge flood wall when on high beams.
Depending on your area, my country is fine so far and I didn’t blind my parents when I tail behind their car as a test.
I never really liked COB for car headlamp. Just too huge of a surface for glare. Practically made my cutoff line into a cotton candy diffusion
But really the brake lights I’ll just stick to stock. Get osram or philips from local stores. Chinese bulbs die too fast to be even worth. My osram 1157 works up till now.
If you’ve made your way to a flashlight/lighting forum (and not a car modder forum), you’re probably aware that optics matter. Greatly.
And in the context of functional signal lights, the implications go beyond whether the tint/pattern is “ugly” or the output doesn’t live up to specifications; there are performance, safety, and legal implications as well.
To this day, I still don’t believe that there are any road-legal LED retrofits substitute for brake/tail/signal/reverse signaling bulbs.
There are a few designs from Philips new / old and Osram that have legitimate performance, but only if the lamp design is suited for them, yet they are still not road-legal.
Those resembling a corn cob, or a disco ball, with multiple emitters, are most often crude, ineffective solutions that ignore physics and are best avoided.
Ambient interior lights aren’t regulated, so one is free to experiment and outfit to taste. Less effort is made to refine the optics, so differing designs can still produce acceptable results.
In this context the one advancement that has proven to be beneficial is the development of “filament” LEDs. I’ve experimented with the cheap festoons from AX and they can serve as an almost indistinguishable substitute for traditional festoons, especially the “warm white” versions. These types of emitters have become much more prevalent in household bulbs with clear globes designed to mimic traditional filament bulbs.
They may not satisfy those who mainly seek the “gee-whiz” effect from their modifications, but their greater efficiency (~1W) allow for prolonged run time and less power drain, as opposed to the 5W/10W traditional festoons consume.
Okay, now you’re getting into my territory. :laughing:
I converted all my interior bulbs to LEDs. What you gotta do is not just find out what bulbs go in there (194, 168, etc.), but physically open the thing and see how it’s oriented, how much space, etc., and then pick the right bulb(s) for that.
Eg, most 194 equivalents are 5×5050 COBs, 1 up top and 4 around the periphery, but you can get stacked bulbs with 9 or even 13 (2- and 3-tiers, respectively) if you can fit them.
So in the rear map-lights (top-center) and rear interior lights (near the door), I could fit… I think it was the 9s. Nice WW LEDs, hella bright, fit perfectly.
In the mirror, again, entry light and 2 map-lights, similar situation. Center dome, the bulbs “lie down” instead of fit in a hole, so I again used whatever WW bulbs fit.
Glovebox, center console, those are hard to get to, but do fit only 5-LED bulbs. Forgot which ones I changed and which I left. Leave the lights on a few minutes, and those that burn you when you touch ’em are the original bulbs, whereas the cool-to-the-touch ones are LED.
Lights for the rear tag, dimmest NW LEDs I could find. I don’t like when they’re overly glaring, so as long as they light the thing enough to not get me a ticket, I’m good.
Puddle lamps (bottom of the doors), pain in the ass to get to, left those for now.
Rear lights, turn and reverse, are great.
You can see how they’re long and narrow on the bottom, so I got “bulbs” that were essentially flat, and oriented so that the light would shoot from the left/right sides. Reverse is NW-to-CW, not too bad, rather shockingly bright compared to the original hotwire bulbs, and the amber turns are amazingly bright as well, and I love the “snap” of LED vs gradual fade in/out of hotwire bulbs.
Now, the current is measured internally, and will show bulb-out warnings when activated, so I put something like 33Ω to 50Ω resistors — NOT NOT NOT the retarded 6Ω resistor kits you find all over the web — to shut it up. They draw only only only the minimum amount of current needed to shut up the warning, NOT act like a dummy bulb in itself (where you could unplug the LED bulb itself and still have it show fine).
Okay, other car, same dealy as far as interior bulbs.
Front ambers I got from JDM ASTAR on Amazon, kick-ass bulbs, hella bright. Yeah, same 3:1 bright/dim ratio which ain’t so great, but I could live with it.
Rear brake lights (dual-filament), the red JDMs are somehow amazingly good. Either the ratio is a lot more than 3:1 and closer to the proper 10:1, or it’s just the way they’re situated, dunno, but they outshine hotwire bulbs. And I was running 40W bulbs (3357, 3557, 3757, whatever) instead of the usual 32W ones. Click rate is determined by the relay, and y’know what? I left it. I actually like the fast-blink. More “nervous” and attention-getting when changing lanes.
Marker lights all around, either JDMs or Yitamotor bulbs (amber/red). The red ones in back, I got longlonglong 13×5050 bulbs, which still fit beautifully. Think the front ambers I only was able to fit 9×5050s.
My only issue is that in this car, the front ambers were the “CK” type, so they popped fuses when I put in “regular” bulbs. The rear bulbs were normal, not CKs, so that’s why I didn’t bother to check first. Stoopit mistake.
Anyway, the only issue with the front ambers is that they can get loose and either go dim or stop working. A good open-palm bitch-slap to the top of the headlight housing jiggles ’em back into place. Probably will at some point either solder-coat the wires (to make ’em thicker) and/or throw some Deoxit on ’em.
Headlights for either car, I’m not touching LEDs. An H9-to-H11 “conversion” of the bulbs should be enough. 55W to 65W, yet twice the lemons.
From previous orders:
Some nice 13-LED WW “194”s
5-LED WW “194”s
https://www.amazon.com/gp/product/B00Y1CFCMY/
The wife’s Honda. My Prev Patrol and current D-Max Ute.
I installed LED’s in all.
Chinese the first time.
After that I found the Osram more/better natural light But much more exxy.
Now. in Ute and happy with, I have CHINESE C6.
(H4-6000K) COB. headlights. around $37AUD a pr .
Recommended by friend who runs a fleet of utes (15)
Clean. sharp cut off. great throw WHITE beams.
Incorporated with single row LED 20in Bar. I have 400+% more, white light. That see forever.
The local ones both, 3or4 x more expensive than Chinese and definitely give better beam and quality. But.
These C6 are definitely waaaay better than std lights and been in ute for around 4 yrs now.
Half the home and the caravan are LED too.
Also, be careful with the Main beams and others too
They come in multiple outputs. Get the highest rated. Some are insipid. The reverse are the worst.
I tried 2 sets.
Ended up buying 2 x square 4in, 4wd lights for $23 AUD del.
Mounting them on rear top of ute tray cover.
with a 3 way sw in dash. On. OFF. or Auto with rev lights.
Magic.
When clear behnd. they light up a good 40ft area behind ute for camping/fishing. and use NO power.
I wish there were at least one known good company to buy LED headlight bulbs from, with no guess work. For some styles of bulbs, the exact placement of the emitters is crucial to the proper operation of the bulb. Also, the size of the LED matters a lot in most headlight assemblies. Most LED headlight bulbs seem to be made to get the most Chinese Lumens out the front. They use huge emitters that won’t provide the right beam profile when used in the stock headlight assembly. While I want a lot of lumens, what I want most is a nice, throwy beam of Neutral White light (most are Cool White :confounded: ). Also, some of my vehicles use dual element bulbs. The majority of the LED headlight bulbs I’ve seen get the emitter placement wrong, and for at least one of my vehicles, the switching direction wrong as well. If only Richard would make some replacement headlight bulbs and sell them at MTN LITEbar.
I recently tried this Suaoki car LED headlamps:
Edit: I just fully read the op and it only asks for regular interior/signal lamps and not headlamps.
There are options for professionally installed, DOT-compliant LED retrofits. It's a bit different than buying the replacement bulbs online from China.
I looked around, and it's probably pretty tough to get any sort of official DOT-compliant certification for a drop-in LED replacement for halogen. In most areas in the United States, if you're going to try to use one on-road, I'd pay attention to the light cut-offs. If you pay attention, you'll notice factory LED/HID headlamps on low-beams will have a sharp cutoff that should stay level with the rest of the car. This is to prevent blinding others (though sadly ineffective when a lifted truck tailgates me). This is also generally enhanced with some sort of leveling system on the vehicle, so if you load 500 lbs over the rear axle, the headlights aren't suddenly aiming up by fifteen degrees.
Another thing that I hate seeing is light bars everywhere on cars these days. Most states require that off-road lighting (classically the large halogens over top or on the grille of a pickup) be covered during on-road use. The same regulations would apply to light bars, but I never see them covered and it doesn't get enforced.
Makes me want to get Anduril on my L6, configure tactical strobe to use the FET, and point it backwards for the next light bar I see...
(Sorry for the rant, can anyone tell I got tailgated by another light-bar Jeep yesterday?)
I recently installed morimoto headlights in my 2015 f150 and they are awesome. They are a complete replacement.
Will be replacing my fog lamps as well and then look for different options for my tail lights.
A colleague from way back had… some boxy old car, a Honda, I think… with a squared back/trunklid. He slapped on some of that garish 8” wide chrome tape that idjits slather all over their cars (bottom of the doors, panels, etc.), right across the trunklid.
If you were following with lowbeams on, no big deal, as they’d (if correctly aimed) be hitting just low enough to not catch the tape. But if you tried hitting him with the brights, you’d get blinded in return.
Was quite clever, I thought. Looked ugly as sin, but was functional.
The thing I hate about those light bars is that they have almost no throw, so they’re not helping the idjit using them on the road anyway. They’re just one big glare. I’ve wished so many times for a Candela-seeking heat laser mounted to my car. It would automatically point at the offending source and take it out quickly and permanently. :smiling_imp:
Hard pass on those.
These “194/921/t10/t15” bulbs are sooo much brighter.
Ive installed a ton of leds over the years. I have an auto detail/customization shop. Ive tried buying from most of the suppliers, even expensive ones like vleds. Heres a truck i did the other day. You can see the difference between one of those 13 led type that you posted and the one i linked on the 3rd brake/cab light.
!Imgur: The magic of the Internet Imgur: The magic of the Internet Imgur: The magic of the Internet Imgur: The magic of the Internet http://imgur.com/ZXaR54v Imgur: The magic of the Internet Imgur: The magic of the Internet Imgur: The magic of the Internet!
quote=Lightbringer]From previous orders:
5-LED WW “194”s
[/quote]
Morimoto round led foglamps are excellent and would match your headlights
Surely you’d want to know if a bulb fails, which would happen with the 6ohm resistor but not with the 33-50ohm resistor? Am i missing something?
Good info though, i have H9 bulbs in a projector lens which are dim, even with upgraded Philips X_treme Vision bulbs, Would be interested to know what you think of the H11 upgrade if you do it. (Am leaning towards to Philips Ultinon LEDS over the H11s at the mo).
I’ve got something similar for my backup lights. Flat like that, most of the LEDs are facing the long-axis of the reflector (see the pic above). Went up’n’down through my amazon orders, couldn’t find which bulbs they were, though.
Not for interiors, though. I’d get sunburn from something that bright. And I went out of my way for WW, because I just like that “relaxing” color, especially at night. 5-chip LEDs were okay, but the 13s were way nicer.
Thing is, my interior fixtures don’t have reflectors, just white-plastic to reflect light, and facetted lenses to spread the light. So when I found I could actually stuff the 13s in there and they’d fit, well, yay me!
Ever notice that so many backup lights are tinted? On VWs, they tend to be tinted gray, some GMs have they tinted orange-pink, even on my old Regal the openings are “slotted” to cut down on outbound light. Wtf??
David EF.
2 things.
Headlights also have Left hand offset on beam and Right hand. Depending on left/right hand drive.
Buying from China check that. All the ones I’ve got. H4
have been simple drop ins as long as you have small hands.
Look on You tube for reviews. (Veh, LED’s)
There are some good Chinese ones out there.
With those Bars and throw.
Get the single row 10w LED’s NOT the 3w dual/triples.
The 3’s are spreaders.
Hence the combo’s of outer and inner lights on bar.
Single row ARE real good throwers.
Mine, 20in. throws forever. Cold White too. not warm white.
It gives clear sharp trees. over 600mtrs down our road here.
There’s essentially 3 things:
  1. trusted source, 2) LED tint, and 3) cost.
You can pay handsomely from a place like deautoled.com, or store.ijdmtoy.com, where they assure error code free LED’s. Or you can try your luck with lesser priced LED’s from other sources. The cheaper ones seem destined for shorter lifespans. I’ve used about 3 different cheaper sources over the years, both auto and home… and most died after 1~2 years of use. I haven’t bought any newer ones lately, though I’ve been looking as the field has changed yet again (more aggressive offerings for good prices).
My dissatisfaction for interior LED’s had been with tint. Even the pricier ones seemed to go overboard on cooler tints, as if warm looked too much like incandescent and wouldn’t sell. Cool is too harsh. Ideally, I want something neutral white that leans warm. So cooler than incandescent, but not bluish like so many LED’s.
Czech out those 2 links I posted. Both are WW, both are quite nice!
Last week or so, I “argued” with someone as to whether/not my interior lights were LEDs or hotwire. He was insisting that LEDs are that nasty Angry Blue™ and mine have to be hotwire bulbs, because they look so natural. :laughing:
For the tint, there is now the Luminus SST20 with high CRI (4000K and below).
I think it can be mounted on something like that as the SST20 is 3535 form factor. But no one got the idea…
all of this LEDs W5W (T10) and C5W are shit! =(
I try more than 10 types of W5W
some types of w5w and w10w
It will die after 1-6 month!
The most tenacious what I find was this
But after some month some of the lines of leds will die. But it will work with leftover LEDs.
Why? Because of hot. I mean it is not with aluminum pcb, it is with glass textolite what can not let heat away from the leds. And it is with ordinary smd resistors. When you car is muffledб it is about 12v, when engine is work - it is about 14v. Current with 12 and 14v is different.
Also there is really cheap leds with tiny crystal and they work to the limit (works with maximum current)
I upgraded C5W by aluminium radiator 14x14x6mm, but it is also with glass textolite with poor thermal conductivity.
Now I finalized drawing the pcbs for C5W (C10W) and finally (15-20 hours) pcbs for W5W (T10) LED lamps with TRI-R 3030 smd LEDs SunLike and NSi CCR - Constant Current Regulator & LED Driver (I call it smart resistor)
How much time need to draw pcb board?
If someone interesting, C5W will cost about 5$
W5W (T10) will cost 5-10$ (depends from led quantity)
1pcs 3030 SunLike led cost 0.5$ in my web-site
