✌ FREEME- ASTROLUX MF01 Mini 7*SST20 CRI95 26650 ANDÚRIL Flashlight Group Buy - $45.99
Depending on unit price, maybe all of the above!
What do you guys think of aux lights that matches the paint? Except the black light would be hard to manipulate :person_facepalming:
What about an actual blacklight? UV
I’m digging these color options. I think it could lead to greater sales because of the mix and match opportunities and the novelty factor. Throw in a good ui and decent components and you’ll have a grand slam.
UV is “black light” :wink:
That would be awesome… I would take the blue and black one then!
Red - Green - Blue and Non - Anodized or Silver dont know…
I’m guessing none of these are hard anodized. :-/
Interested depending on price and features…
this would be cool indeed. :+1:
if they make this right it can be a very good competitor to both fireflies and emisar, i hope atleast a few of the color options will be available on purchase later on and with matching aux leds would really be nice if they could do.
AUX leds are awesome feature for modern lights but i seldom switch ON. Too many lights lying around, i afraid battery gets fully drained by accident.
I would love to see a beamshot comparison to a D4S…
+1
But they have Low voltage protection built in the driver
And so do the aux LED boards if you’re using a lexel design.
Interested.
Can someone make an educated guess at the expected turbo output powered off a single 26650? And for how long?
The drivers LVP only works when the light is turned on. It does not work when the light is turned off so high parasitic drain can still be an issue.
You really do need one of Lexels designs that can shut the aux leds down completely at low voltage if you want to be on the safe side.
You want to use protected cells if you want to be super safe.
The best thing to do is to mechanically lock out a light if you are done using it. Then you don’t have any of these potential issues.
But the MF01 aux driver is designed by Lexel so it shoukd be the same as the ones in the fireflies
What is the driver design, a FET?
If so, then expect very high output for a very short time on turbo. Maybe 20-30 seconds, but this depends on the battery and the thermal mass which we don’t know. So maybe longer with a high capacity cell and if it has a lot of mass. The design is like a more powerful Emisar d4s. You would definitely want to run it a bit below turbo if you want longer run times.
This is all a guess, we have to wait for tests to see actual numbers.
Aux board has LVP shut down and low battery indicator
