Logic flaw is that 1 click only adds 1°C but start for ambient is 0°C while start for limit is 30°C
So clicking once for each will tell the light that (whatever the real temp is) the ambient temp is 1°C and set the limit to +31°C so that a +30°C from the actual ambient temp and is the same as (with an ambient temp of 20°C) clicking 20 times for ambient (=0+20) and 20 times for limit (=30+20)
Not sure if this is as clear as i'd like it to be ...
Can’t find it back but it was mentioned before: in muggle mode my FW3A does a completely needless stepdown from highest to lowest after a minute or so, sometimes faster sometimes not at all. Nothing is the matter though, not hot at all, battery voltage over 4V, I have set the right tenperature and the FW3A blinks it out correct too, temperature limit set at 52degC.
Yeah, seems I had a thick-headed moment there. :weary: So basically there’s an automatic 20C padded to BOTH values of current and limit. Current starts at a base of 0, and Max at 30. So first click means 21C and 51C respectfully. And each successive single click in the menu just adds 1C. I get the logic of the 20C padding, because it’s a safe base value, and saves having to click 20 extra times for each value.
So when I clicked 20 times for the max limit, it was 50C (FW3A) PLUS 20C more… making it 70C actual. That’s 158F… I’d read a while back that 60C to 80C is about the safe maximum operating temperature for LED’s, depending upon the maker and LED type. And the longer you burn at a higher temperature, the shorter your LED life. So maybe it’s safer to set max limit to 60C (10 clicks).
By “padding”, I meant figuratively. Maybe there’s a better synonym to use. Maybe “base value.” I don’t know. We’ve got 2 things being talked about — actual temperature versus FW3A click count. I think it could be better clarified in the instructions. It’s a little confusing for those of us who are not experienced with thermal management settings.
Current Temp is this isn’t it??. If room temp is 19C & light is at room temp. Click 19 times. If room temp is 21C, click 21 times. Etc., etc., etc……
I thought Temp Limit started at 30C. To get 50C you click 20 times.
This \… taken straight from the FW3A User Manual that came in the box:
Thermal configuration
Look at a thermometer to check the current room temperature. Let us assume it says 21 Celsius Turn the light off and wait for its temperature to settle to room temperature.
Go to TempCheck
When you are in TempCheck, then click 4 times to enter thermal config mode, and calibrate the sensor.
Thermal config mode has two settings:
1. Current temperature Calibration.
Click once per degree C to calibrate the sensor. For our example, the ambient temperature is 21 C = click 21 times.
2. Temperature limit.
This sets the maximum temperature the light can reach before it will start doing thermal regulation to keep itself from overheating. Click once per degree C above 30. For example, to set the limit to 50 C, click 20 times.
The default is 45 C (15 clicks).
Hint: If you don’t click,the lamp will leave the value unchanged.
The lowest value the user can set is 31 C, by clicking once.
We’ve all been around here long enough to know that.
A new light originating from BLF always has problems, that is because we try new stuff, and things go wrong trying to get chinese companies manufacturing new stuff. Usually after a few batches most of the flaws are ironed out.
You can jump into the first group buy run and expect flaws (I never can resist that), or you can wait for the improved version and risk having to pay more.
A lot of the above post is not correct information xevious. There is no “20C padding” you mention. Not trying to argue but this wrong info may well confuse if anyone follows it.
This is how it is done correctly… taken straight from the FW3A User Manual that came in the box:
Go to TempCheck
No worries. I struck out the content of my post. I didn’t mean to be an idiot, but what was throwing me off was having read a few comments scattered about, rather than circling back to the actual manual. I made a poor choice on terminology. It should be “base value.” And there’s 2 things: actual temperature representation and the number of clicks.
See, this threw me, from 1st post:
“At the first menu option, while the light flickers and waits for input, click to enter the current room temperature. This is typically about 20 to 25 C, meaning 20 to 25 clicks.”
Then I saw a post from TK saying only 1 click was needed and you’d have 20C set for current temp. No need to click 20 times to get 20C.
I know what you mean by “padding”… that is where you are not correct.
For ambient temp calibration it starts at 0C. If room (ambient) temp is 17C, you must click 17 times for the temperature sensor to be properly calibrated. (1 click = 1C)
Max temp limit starts at 30C. If you want to have a Max Temp Limit of 48C, you do 18 clicks. (1 click = 1C)
Yeah, but I feel like I shouldn’t have been confused…
And maybe I am still not completely clear on this. Because from what you’re saying, if I enter current temp setting and click once, I’ll have 1C set? Current temp just above freezing? Because after I did set that, the light was telling me 21C… (I presume 1C above 20C because of LED temp just a little up from the flashing).
So… yeah. To be safe, click 20 times at the first option and 20 times at the second option. If you’re anywhere close to an average room temperature, that should give it a sane thermal config.
I was mostly just pointing out that, if you click the same number of times at both, it should end up with a temperature limit 30 C higher than your current room temperature… whatever that is. And technically, that can be shortened to 1 click at each option, but only if you don’t care about having accurate values in the temperature check mode.
But it seems that was confusing, so it’d be best to enter accurate values instead.
It shouldn’t be possible for the light to overheat in muggle mode, because it’s limited to such low power. But people wanted it to be really safe, so they can let kids use it. So if it does detect a “getting kinda hot” condition, it doesn’t even try to regulate the output… instead, it panics and drops to the lowest level.
This worked fine in testing, but it seems that some lights detect enough heat to trigger the panic response. It sounds like it’s probably sensing noise in the ADC readings instead of an actual high temperature though.
Do you think it should have the muggle thermal condition removed, so it ignores temperature? It shouldn’t be overheating in that mode at all, and it seems to mostly just cause problems.
