Buy only new version - “Upgrade C4-12” with two yellow button!!!
Old version have frequent problem with springs, dying third slot, not support: 21700 protected, LiFePO4, Li 4.35
Ok got it. BTW what is the difference in the C4 v3 and the C4-12 they both look exactly the same. Are they the same but maybe just a different numbering for Amazon as on Amazon I only find the C4 v3.
Get a analyzing charger for yourself and a cheap trustable charger for your mother. I hardly use my opus cause it’s a big noisy block, I replaced it with gryfalcon 88 for just charging my cells. Even though the gryfalcon has 8bays as opposed to 4 it still looks smaller and makes a lot let noise then my opus. A Littokala can be bought pretty cheap depending on the amount of bays.
What is the difference in an Analyzing charger? I thought they all did the same the C4-12 and Opus BT. But if that is not the case the only one that I see that qualifies in my price range, found in US would be the Opus BT-3100 V2.2 as I can get that on Amazon.
An analyzing charger will charge > discharge > the charge the battery and give you the capacity determined from DISCHARGE. This is the only accurate way to measure capacity.
Lii-500, Zanflare C4, and the Opus BT-C1000 are analyzing chargers.
The main advantage of the Opus is more control and options for charging and discharging. It has some ‘quirks’ that some people dislike. But, it IS more flexible, more powerful, and has more charging options.
A ‘charge only’ charger cannot do this.
The Miboxer C4-12 appears to be only a charger, but a good one. It’s fine if you don’t really want an analyzing charger. But I think you will.
That is a good question there. OK comparing the LiitoKala Lii-500 and the Opus BT 3100 v2.2 I have opted for the Opus and ordering it from Amazon. It is the same price as on BangGood but I get it delivered in 2 days Opus supports more types and the larger battery sizes so that will be the charger I order. I appreciate the advice and assistance and the explanation of what an Analyzer/Charger is.
Ok my new Opus arrived today and I have Eneloop Pro Double AA batteries. These are brand new batteries so I want to verify them. Would I set mode to Test and just insert battery? Also should I change the current discharge rate from default 500mAh to say 700mAh and charge to something like 1000mAh? I’m a newb to an Analyzer charger.
Be aware that one of the limitations of ALL the analyzing chargers is the limited ability to do high amp discharge, if you want to test for that. They use resistors, resistors get hot, so they have to shed the heat. Opus will give you a few more options than many of the others.
That said: pop them all in. Plug in. In a moment all bays will start blinking with [500] displayed. I’d leave it there for now. Press [Mode] until [charge test] come up. Leave it, it’ll stop blinking, and start working. Walk away, it’ll be done tomorrow.
It has to charge them up, then discharge-the part where you get the capacity-then charge back up. When finished you can hit [display] and it’ll cycle through the settings/results. You can hit [display] at any time to see what it is doing.
