Most electronics, including the led, can function above 200degC.
But when Pb/Sn solder is used, the unsolder temperature of all that stuff is about 180degC.
Li-ion batteries can go wrong above 150degC (although high current IMR-type batteries can withstand higher)
But for them to live long and happy lives you should keep them below 80degC.
Your hands however feel pain above 55degC.
And they still feel comfortable below 50degC.
As soon as I insert a battery, the light goes on. I canāt switch it off, the switch erratically changes brightness and modes.
I donāt think itās related to the battery tube or the switch itself. If I connect a battery directly to the head (+ to the spring, - to the threads) it also comes on immediately.
Anybody experienced a similar behavior? What could be the reason for it?
Looks like you clicked 5 times instead of 4 so now the light is locked in momentary mode, what you have to do is to remove the head (only way to get out of the momentary mode is to remove power) and take it back, that should take you back to normal mode.
Hmmm, that really is odd. So it doesnāt immediately go to turbo and stay there? It actually ramps up and down and switches modes on itās own?
My guess would be there is something shorting the driver circuits. Maybe a stray sliver of aluminum or something. You might try pulling the driver out and run a brush or compressed air over the tiny components.
I assume you checked to see if the driver was flat and that the notches line up, then make sure the retaining ring is tight.
No, it does not go to turbo. When holding the switch, it goes to different levels in steps, stays at the brightest. After that, it step-ramps down if i release the switch and hold it again. The driver is flat, however the notches do not align perfectly, so maybe there is a short between the case and the driver? !Imgur: The magic of the Internet! In order to pull out the driver, I assume I have to desolder the wires at the front, right?
I donāt think itās dirty threads as it also happens when I directly connect the battery to the spring and case. I donāt see how the threads could be involved.
What your describing sounds like proper normal function. It ramps up when you hold the button, release and press again and it goes back down.
Are you confused that it goes in steps instead of the smooth ramp? To switch from stepped ramping to smooth ramping turn the light on and do 3 fast clicks.
Well, it turns on immediately when inserting the battery and tightening. And I canāt turn it off. It acts like a twisty.
I have pulled out the driver and cleaned it. Re-inserted it taking care of the notch. Same result :-(.
I am clueless. Somehow, the MCU must be working as itās doing something when pressing the button. The button must also be working. It almost looks like (on of the) 7135 are permanently working so there might be a short somewhere?
Try unscrewing the head and tail cap, screw in the tail cap nice & tight, insert battery, then screw in the head nice and tight. Or try the reverse of doing the head first, then tail. Of course, just be careful of the tail cap as the switch board and button will fall out (not secured in place at all).
I had a similar flaky operation before I did this. Now my FW3A is working great.
However itās happening with the head only when connecting + to the spring and - to the body. So that would narrow it down to the driver board. I desoldered the star, the driver board looks good. Hard to debug though.
Yeah, in reading what you posted about a moment ago, it does sound like thereās some kind of electronic defect going on with your driver board. Probably too expensive to mail back, unfortunately.
In order to turn the light on directly, the retaining ring would have to be making contact with the signal ring on the driver, they should be 2 different circuits right?
My FW3A started ramping up and down as soon as power was connected when it arrived too, I tightened the driver ring, pulled the inner tube out and made sure it was clean and reassembled the switch assembly. Problems cleared right up.
