Is anyone able to post the measurements of 2AA Duracell Durabeam please? Those are needed for 3D modelling.
Thank you in advance
BUMP (Bringing Up My Post)
If this light ever gets made, it would be the perfect opportunity to introduce hi CRI to the public.
Ah yes. Sofirn needs to create an updated D20A. I have mine as my bed light. I navigate with the red led
Just giving this one a little bump.
2AA Dependable Compact Flashlight from Sofirn on the horizon
Have prepared two versions of UI.
Still can’t decide which one would suit muggles better
Full size here: https://i.imgur.com/dUv3tvv.jpg
Full size here: https://i.imgur.com/sJtLIr5.jpg
I would be grateful for any criticism. The more brutally honest the better
Additional thought: Maybe we will be able to use a driver developed for Sofirn SP10S “BLF edition” with Andúril
You let the cat out of the bag
Here are earlier alternative variants that “didn’t make it”
or
and this one is the final(ish) design:
The front is inspired (on Sofirn’s suggestion) on Russian headlamp YLP Panda 3
The OLED is similar (again on Sofirn’s suggestion) to Fenix’s UC52:
I would probably have to buy this with my love of side by sides. Do we know what emitters they want to use?
#48
Is says Nichia E21A - the little ones around the main reflector.
For the UI, the one Nitecore uses on the EC4 series is fantastic, but it doesn’t have any way to change between flood and throw - that definitely clutters things a bit.
I would suggest staying away from built in charging and the OLED. There are almost no AA lights with built in charging for a reason, and the screen is just a point of failure and a major design challenge. The two combined don’t bode well for water resistance or AA support.
The idea to use Nichia NVSWE21A (sm453 r9080) was based on hope that it would be possible to create design of Sofirn’s DCF01 inspired by Muyshondt Beagle MK. I and McGizmo ls20.
The design was sent to Barry and his response was:
‘What I can say is to get high CRI E21A is not a issue, Sofirn will handle it.
One main led surrounded by 4 E21A can be done but that make it a expensive light’
I asked how much would it cost and Barry promised to come back with a rough price.
Unfortunately Sofirn is worrying that it would make the flashlight too pricey for possible BLF Group Buy and later for average customer.
For this GB to happen it needs to secure 500 pieces in orders.
Same happened to the idea of taking some inspiration from this camera (Would be nice to have a rotary switch):
Therefore quest for a shape that would allow this flashlight to be manufactured at reasonably price continues.
As this flashlight (with it’s accessories) is intended to be really nice gift bundle the need for a nice feature emerged.
Maybe… a battery indicator like the one below?
And than… I stumbled on ttever3’s mod:
Barry’s reaction: ‘To add a lcd display to show how much juice left is a good design for muggles.’
It’s hard to find a muggle who doesn’t prefer USB charging and that’s one among other things that will make DCF01 a perfect gift flashlight.
We are building here something unique, second to none 2AA head-turning flashlight. The sort of thing that everyone deserves, but most people won’t buy for themselves — therefore a perfect gift. Great for any outdoor adventures as well as for all kind of indoor activities. By putting OLED we already made it more appealing to potential customers. By adding USB charging convenience (with information on display of time remaining to fully charged) we are making their choice of proper flashlight even easier for them.
The question will be asked by many:
What happens when someone makes the mistake of trying to recharge the AA primary batteries inside the light?
Well… First of all, there will be rechargeable batteries in the bundle/kit and rechargeable batteries recommendation printed both on the box and inside manual. Possible leakage or explosion from overheating will be shown in pictures in manual and put in CAPITAL LETTERS.
The flashlight will be designed to work on alkaline batteries, but ONLY in emergency situations. It will be not advised to use alkaline batteries on daily basis.
Any type of power source requires intelligence to be used safely. It really doesn’t matter if it’s Alkaline, NiMH or Li-ion.The risk of someone accidentally charging an alkaline in this light is not any more than someone accidentally charging an alkaline in a stand alone charger. If it’s really that big of a risk, there won’t be any consumer AA chargers on the market. I think warning stickers and labels should be adequate.
At the beginning there was an idea of removable pocket clip. Something like this:
But than I heard of Frelux Synergy 1 and the more I’m thinking about it’s clip the more I like it. I also like a small width of the knob.
Another light that can be used as an inspiration is Acebeam UC15: https://imgur.com/a/1IoGTyC
We could change it a bit and use a clip and a knob similar to one used in Frelux Synergy 1:
Did this go anywhere? Is Sofirn working on it?
If it is not an issue to get E21A, I hope that they will use it for new or already existing flashlights real soon.
I prefer stepless.
I think stepless is really easy for all to understand and get the right light level, especially with separate buttons for up and down. I like the memory with shortcuts to low and high that you have for both UI’s. In the bottom left of the stepless UI, the description of how to change emitters says to hold, on the right it shows a short press.
I like the general look of the light, but would prefer that the thickness was uniform and minimized, 2 cm or less, to fit comfortably in more pockets. The clip that attaches under the screw on the end ought to work well for deep carry.
Thank you 1332332331!
Updated:
Full size: https://i.imgur.com/FYwG7Gl.jpg
Some more questions:
2) What about double click ?
What functionality should be implemented? Or should we leave the double click inactive?
3) If needed - bicycle mode could be activated/deactivated by prolonged press (6 minutes?)
Is it necessary?
Will take a look at the UI and will try to give some feedback! I completely forgot to tell you something about this
Earlier you said that even rude comments were welcome. This may look it is, but it is not intended as such.
I thought this thread was about reviving one (or some) of the iconic primitive flashlights that we remember from our youth(s). And can serve as the start of an addiction to a whole new breed of flashaholics. Flashlights with parts that are more contemporary, but without changing the original character. With a price that has gone up from the historic $1 to $5-$10 today. Part of those historic lights was the ultimate simple UI. Most of those had a momentary switch that could be fixated. That’s all. Perfect for novices and for those who will never transcend that level. Lights that last half a lifetime, at least in our minds.
You present us a well-thought, but not-very-simple, UI. That’s a bit beyond the original scope (IMHO).
But we all do remember the Sofirn C01, that without much delay was succeeded by the Sofirn C01S.
From an on-off twistie with a 5mm led into a small light with adult character as greatest common denominator of our wishes. That’s why I propose to reserve your UI for implementation in the S-version of this revival light.
So, I took a look at the last UI you posted!
I general I like it, but I have some doubts and comments. I didn’t read the whole thread, so please ignore questions that could have been answered before! I start with the the end:
- “runs on single AA battery”: Alkaline and Ni-MH? Also, this is just to inform that 1 single cell will power the flashlight, but it will not achieve the lumens it is supposed to with 2 cells, right?
- “low voltage protection”: when the battery is low. The over-heat protection will be something different, I guess.
UI
- click for ON/OFF in button 2 = :+1:
- shortcuts from ON/OFF to ML (button 1) and High (button 2) =
- two buttons to UP and DOWN brightness by Press & Hold =
- Possibility to start on ML and keep on “ramping up” the light till the desired level =
Doubts:
- Press & Hold Button 1 - from OFF it will enter Moonlight without having to press button 2, right? If so, shouldn’t the dotted arrow in the scheme be red instead of black?
- Stepless dimming - will it be fast enough so that people don’t get “bored” with choosing brightness? Meaning: most of the lights I have with that system take a while and are not fast as a ramping UI. Just wanted to be sure on this
- Will the flashlight memorize the emitter(s) we have selected in our previous use?
- The part mentioning the that High will “step down to Low 10 minutes after power OFF”, is this a safety “don’t blind anyone” measure?
Concerns:
- As Henk4U2 mentioned, isn’t this UI too complicated for muggle people? Pressing ON/OFF in the button 2 and cycling between three well spaced and useful modes (L-M-H) through singles clicks in button 1 would be easier. This is more a flashaholic UI, even if we think it is simple!
- Not sure if adding “blinkies” such as bike strobe or strobe is very useful. Still if so, let it be hidden and not accessible by double clicks (triple or more clicks).
Sorry if some of the questions are dumb, but I am just trying to perceive how I would feel with this light in the hand.
And good work so far
