Vbatty ICR16500 1200mAh (Blue)
Official specifications:
Brand Name: vbatty
Model Number: 16500 battery
Nominal Capacity: 1200mAh
Type: Li-Ion
Storage Temperature: –20 ~ 60degree Centigrade(1 month),–20 ~ 45degree Centigrade(3 month),
This battery is a bit uncommon in size being 16mm in diameter and 50mm long
At low current the discharge curves tracks very nicely, but the capacity is slightly below rating. At 2A or above the battery do not look as good.
Conclusion
This battery is fine at 1A and below, but do not work well at higher currents.
Notes and links
Graphical comparison to other LiIon batteries
Table with all tested LiIon batteries
