mortuus
(mortuus)
May 17, 2019, 8:23am
274
this would be cool indeed. :+1:
if they make this right it can be a very good competitor to both fireflies and emisar, i hope atleast a few of the color options will be available on purchase later on and with matching aux leds would really be nice if they could do.
freeme
(youtube.com/@1thedeals)
May 20, 2019, 2:23am
275
AUX leds are awesome feature for modern lights but i seldom switch ON. Too many lights lying around, i afraid battery gets fully drained by accident.
AlexGT
(AlexGT)
May 19, 2019, 5:49pm
276
I would love to see a beamshot comparison to a D4S…
SKV89
(SKV89)
May 19, 2019, 6:03pm
278
But they have Low voltage protection built in the driver
TrueRMS
(TrueRMS)
May 19, 2019, 6:08pm
279
And so do the aux LED boards if you’re using a lexel design.
patmurris
(patmurris)
May 19, 2019, 9:36pm
280
Interested.
Can someone make an educated guess at the expected turbo output powered off a single 26650? And for how long?
JasonWW
(JasonWW)
May 19, 2019, 10:11pm
281
The drivers LVP only works when the light is turned on. It does not work when the light is turned off so high parasitic drain can still be an issue.
You really do need one of Lexels designs that can shut the aux leds down completely at low voltage if you want to be on the safe side.
You want to use protected cells if you want to be super safe.
The best thing to do is to mechanically lock out a light if you are done using it. Then you don’t have any of these potential issues.
SKV89
(SKV89)
May 19, 2019, 10:17pm
282
But the MF01 aux driver is designed by Lexel so it shoukd be the same as the ones in the fireflies
JasonWW
(JasonWW)
May 19, 2019, 10:22pm
283
What is the driver design, a FET?
If so, then expect very high output for a very short time on turbo. Maybe 20-30 seconds, but this depends on the battery and the thermal mass which we don’t know. So maybe longer with a high capacity cell and if it has a lot of mass. The design is like a more powerful Emisar d4s. You would definitely want to run it a bit below turbo if you want longer run times.
This is all a guess, we have to wait for tests to see actual numbers.
Lexel
(Lexel)
May 20, 2019, 5:57am
284
Aux board has LVP shut down and low battery indicator
Marc_E
(Marc E)
May 20, 2019, 10:07am
285
The blue and red have got me interested.
rost333
(rost333)
May 20, 2019, 11:47am
286
non-anodized like this one
McLight
(McLight)
May 20, 2019, 7:34pm
287
@rost333
looks bigger than i expected… but nice
JasonWW:
I think the driver is gonna be similar to the FW3A. FET+7+1. Default ceiling will be maximum 7135 and then turbo will be full FET. Ramp ceiling on the FW3A is about 700 lumens which is decent for maximum regulated current on such a small light. On this particular light maximum regulated current might produce in excess of 1000 lumens. It will be very handy!
Sirius9
(Sirius9)
May 20, 2019, 9:41pm
289
Blue tint/ano is quite nice.
JasonWW
(JasonWW)
May 21, 2019, 8:36am
290
Rost333 is showing a different light, so size is not comparable. He was simply refering to the finish.
I don’t know how good a raw aluminum finish will be. They tend to oxidize over time and look nasty. Anodization maintains it’s appearance.
G.P
(G.P.)
May 23, 2019, 3:17am
291
JasonWW:
They could clear anodize raw aluminum, like Fireflies does.
JasonWW
(JasonWW)
May 23, 2019, 3:20am
292
Is their “clear” anodized really that or just an aluminum color anodization? I haven’t been following it.
mortuus
(mortuus)
May 23, 2019, 10:48am
293
no info has been posted afaik only the small teaser image.
