I assume the reason the temperature is not configured from the factory is that nobody wants the assembly line to include setting the flashlight aside for half an hour to equilibrate, then having the assembler follow the clicking instructions.
There are likely always going to be things BLF folks have to fiddle with adjusting because the builders can’t do it.
Setting the current temperature seems easy enough. I may be wrong about this. I am thinking that when the light has come to room temp you should configure quickly before light has flashed on and off a lot because the internal temperature will be stedaly increasing.
I guess if it is close may not make too much difference. I know that after setting mine and going back in to check the setting it never reads the same as where it was set.
Make sure you start with the light turned off.
Also make sure you are not stuck in Muggle mode. I think Muggle mode will step the light down quickly without being too hot.
When in battery check mode it blinks the voltage (4 slow then 1 fast is 4.1v). In sunset it’s a steady light. In beacon it blinks once every few seconds. In temp check it blinks out the temperature (2 slow blinks followed by 8 fast blinks is 28°C for instance).
I’ve reached the point where I need every flashlight’s instruction text saved to my PDA so I can remember what I’m doing.
I find myself wishing for a magic signal that says “lock the light in its current mode so I can turn it on and off without losing the setting” — particularly for the bike strobe, which I use in crosswalks to wake up cellphone-drivers on the streets locally. (The Sofirn SP32A is best for those crosswalks because it wants nothing more than a triple click to start strobing.)
[quote=hank]
I need this too! Last night I was using my Emisar D4 for the 1st time in a while. I KNEW it had NarsilM, I just knew it! Kept trying things, like double click high, double click again for strobe … but no strobe showed up? And I tried battery check, then double click for temp, double click again for version #. Nothing. I thought the light was broken! Took the head off to see if I could see anything wrong. Tried another cell. Was going to contact Mountain about a warranty. Finally went to a D4 search on BLF to see the unique UI. Oh yeah, now I remember! Go easy on me with over 100 lights.
If i want blinking stuff for crossing the road on a Narsil or Andúril, I use 3 clicks for battery check.
It is also a bit milder than strobes, in case you don’t want to blind someone.
Received 4 lights with batteries installed. Checked retaining rings and all were tight. One light would get stuck in the low level strobe and no other modes available when the switch was pressed. This was intermittent and only happened a few times.
Took time to investigate the problem today and I could create the problem by very slightly loosen the head.
I finally cleaned threads and lubed with nyogel. Now I could not create the problem again.
Did not clean contact pads on the board yet but all seems well for now.
