will34
(will34)
May 17, 2019, 12:20pm
279
This one might be your best bet:
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F113684437490
That bare board has great specs, but I find it hard to believe it would be able to handle 60W of output at lower range of input voltage for long times, say 12V which is 5A+ constant input, chargers usually get quite hot at that rate.
chx
(chx)
May 17, 2019, 5:25pm
281
Looks quite great, thanks! However, the size and price is a bit overkill. For such multiport usage, the MagicFox PD180 京东(JD.COM)-正品低价、品质保障、配送及时、轻松购物! is cheaper and has higher wattage.
I plan to feed it with 20V. The Lenovo 135W charger looks like great target. https://www.reddit.com/r/thinkpad/comments/bpnc9o/the_p1x1e_small_135w_charger_available_retail/
RD_tech
(RD tech)
May 20, 2019, 2:44am
282
hope you get the better one
JJSEA
(JJSEA)
May 21, 2019, 1:23pm
283
YZXstudio has a newer model ZC918P that does 160W. I bought one off ebay, but it’s also available aliexpress. Like other YZXstudio products, it’s good quality but quite expensive.
The Magic Fox PD180 looks very interesting. I think it is unique in offering PD input. Is it available anywhere more accessible than jd.com ?
xnode
(xnode)
May 21, 2019, 2:16pm
284
If I want to test the maximum output of a charger, which adjustable load can I buy? Some recommendations?
dodge_911
(dodge_911)
May 21, 2019, 3:05pm
285
xnode
(xnode)
May 21, 2019, 8:50pm
286
I’ve found a new meter similar to YZXstudio ZY1280, is it a copy or is original?
MagicFox魔狐U2 UX电流电压USB测试表QC4 PD3.0 2.0 PPS快充协议容量检测 U2表(无蓝牙)送短CC线
angerdan
(angerdan)
May 21, 2019, 9:01pm
287
I’d suggest a load with more power than your charger can use. With USB, 35W are usual:
Electronic load 35W 3A with OLed display J7-f
[image]
Official specifications:
Industrial discharge load USB tester
2016 new upgrade electronic load King
Intelligent temperature control Double adjustment design
USB Dual Adjustment accuracy Electronic Load discharger
Industrial grade long life 35W power continuous discharge
Voltage:3-21V Current:0-3A
Real-time monitoring
Voltage display Current display capacity display Electrical voltage display Power display Timing dis…
Electronic load ZKE EBD-USB
Electronic load ZKE EBD-USB+
[image]
Supply power: online USB power supply (5V)
Voltage range: 0.05-21.0V
Current range: 0.05-4.000A
Test mode: constant current discharging, QC2.0/3.0 trigger, MTK-PE trigger, USB current voltage detection
Max power: 35W
Computer control software: support EB online software test
Weight: 66.5g
I bought it from ebay dealer electronics_lee (It was called EBD-USB, but the EB softw…
Electronic load DTU-CC01
[image]
Material: PCB
Display: 128 * 64
Input Voltage: 3.6V~30V
Input Current: 0.2~3A
Voltage Resolution: 0.001V
Current Resolution: 0.001A
Rated Power: 25W
Max. Power: 35W
Wire Resistance Measurement: Pressure-drop method
Input Interface: USB-A, TYPE-C, Micro USB
Capacity: 0~9999.9AH, 0~9999.9Wh
Protocol Trigger: for QC2.0, QC3.0, FCP, SCP, AFC
Working Temperature: 0~70°C
Item Size: Approx. 11.5 * 4cm / 4.5…
JJSEA
(JJSEA)
May 22, 2019, 1:06am
288
The Magic Fox one looks like an unbadged version of WEB-U2 (more recently branded as WITRN U2)
There are very similar USB testers sold under several different brands and the relationship between them is not clear to me (e.g. YZXstudio, WITRN, WEB-, POWER-Z, AVHzY)
RD_tech
(RD tech)
May 22, 2019, 1:53am
289
not , it is web-z meter , they are different
RD_tech
(RD tech)
May 22, 2019, 1:55am
290
they are all USB load , but the first one is a trash
JJSEA
(JJSEA)
May 22, 2019, 2:48am
291
I have the RD LD35
https://www.aliexpress.com/item/32882318330.html
This is just a load: if I want to do triggering, I prefer to do it separately.
RD_tech
(RD tech)
May 23, 2019, 12:43am
292
this is our LD35, it don’t have trigger function, if you need trigger function, you can check our other version HD35
JJSEA
(JJSEA)
May 23, 2019, 12:55am
293
I believe it has only QC trigger function. It would be great to have a load that also had PD trigger function.
RD_tech
(RD tech)
May 23, 2019, 1:09am
294
for not , there is not PD trigger load
JJSEA
(JJSEA)
May 23, 2019, 1:33am
295
I found another YZXstudio DC-PD adapter on ebay ZC823x3 (it’s also on their Taobao store): 180W, 6 ports arranged as 3 x 60W USB C/USB A pairs, and DC or PD input.
https://www.ebay.com/itm/ZC823x3-PD-180W-Multi-Protocol-Fast-Charge-Apple-Xiaomi-Huawei-Samsung-QC4-PD3/133054595939
I ordered one.
RD_tech
(RD tech)
May 23, 2019, 1:43am
296
this is a charger, not a load, I just talked about the USB load
will34
(will34)
May 23, 2019, 8:07am
297
Do you plan to release a usb load with PD trigger and higher power capability?
Yes, I’d love one.
I’d also be willing to pay a pretty penny for one.
