[♛ FreemeGB] ASTROLUX FT03 XHP50.2 (3V) 4300lm 735m 26650/ 21700/ 18650 Flashlight - SHIPPED!
No, no no -- I have NarsilM running on several 6V LED lights, of course. Even my super S88 clone 16X XHP50 light at 35K lumens runs on NarsilM.
The "LDO" SMD part is the key, used in place of the D1 diode, and we got several BLF designed drivers using it. Also, looks at the Astrolux and Haikelite 6V lights NarsilM runs on, with drivers designed by TA.
I personally have had no problem whatsoever running a FET+1 with a single XHP70.2, but if you take 3 of them in parallel, amps gets way up, and I've gone thru killing several 7135's in those configurations, which is why TA went with a totally different approach with the high amp lights - doesn't use a 7135.
Interested!
Thank you mrheosuper and Tom.
I stand corrected.
Interested
Interested
Interested, depended on final specs & prize
Interested
Interested !
Interested thanks
ETA?
Interested!
Interested
Interested
If turbo can be memorized or in the mode sequence I’ll take at least 5 pieces. At least give us that option to program this if we would like it. But still keep the double click to turbo from off or in any mode.
Are there specs already? Lumens rating? Available LED tint? Is the UI still the same NarsilM v1.3?
I’m tempted to go with the Convoy M3 since these guys appear to be dragging their feet. At least a heads up or something.
Interested
Very interested - I’d love a CREE XHP70.2 version.
interested for NW
I am interested
