Haha, yeah. Iām probably quite a bit more north than most people here.
Donāt want to advertise my location that much on the internet but letās just say where I am as far as night/twilights go there will only be civil twilight from next week till middle of July. You can figure out the latitude from there. Which isnāt that far north considering Iāve spent quite a few summers in Rovaniemi where you can experience 24hās of daylight for a month during the summer.
My 2 FW3Aās arrived via DHL yesterday. I chose one of each tint available at time of ordering (a 3D and a 7A) and had chosen to get batteries to feed them too, a Sony VTC6 (first one this brand and kind in my 18650 stash) and a Samsung 30Q.
No extensive reviews or beam shots here. All I gotta say is, dang that 7A warm white is definitely way more orange than white (not white to my eyes at all). Yes it was my first foray into 3000K warm white emitters but dang it was a big differenceā¦ it was more orange/yellow than my Mag2D with ROP HI hotwire mod (w/ FiveMega 6AA-2D adapter) that was warmer than any of my NW LED lights I have including my Manker E14 quad Nichia 219 (maybe the ROP was a xenon bulb, itās been a while - built it in 2009). Maybe Iāve gotten used to the daylight white of my NW LEDs but the 7A seems more incandescent than what I used to recall as incandescent.
I guess itāll take getting used to EDCāing it.
Both lights did work as intended right out of the box and all the threads were clean (no burs or shaving) and well lubed.
Great jobā¦ now the wait for the next BLF project light (the lantern).
Actually I did calibrate. The issue was head tightness. Once I applied a little more torque to the head, it stopped doing that. Whatās the physical dynamic at hand when this happens? As I understand it, with the inner tube not completely seated the emitter shouldnāt have current. So sufficient tightening makes for a solid connection and the light functions. Is there some āin betweenā state possible, where the inner tube has contact, but not fully, and thus thereās some kind of weak voltage issue?
FM (frequency modulation) radio was invented in 1933. Iād call that old! LINK. :laughing:
But I still listen to it. Iām an NPR junkie (WNYC). I use an Apple iPod Nano, both 6th and 7th generations. The 6th is the smallest radio enabled MP3 player ever made. You clip it on the top of your shorts waistband and youāre good to go for a run. The 7th generation is a little larger, with more enriched UI; I usually take that with me on multi-day trips. Itās unfortunately not WiFi enabled, so you canāt download podcasts over WiFiā¦ need to use iTunes.
Thatās great you have that resource in France. In the USA, many of us utilize podcasts. Easily downloaded audio to MP3 players. I have an Apple iPod Touch (5th gen, with retractable lanyard loop) that is WiFi enabled, so I download all kinds of programs to it without requiring that cumbersome iTunes.
Iāve got an iPod Touch 3rd gen that I have been using for the last decade now. Iām not a fan of Appleās ecosystem, but damn they can make a durable piece of technology. I doubt newer devices would run for as long without issues though. Itās not profitable to have somebody like me only buy once, rather than once every yearā¦
Iām still a big radio fan though. I listen to it a lot in the car and at work. Itās the only way I keep up to date with what music is out now. I should probably check that Spotify out at some point, but Iām just not into music enough to justify paying a subscription.
The earlier Apple iPods were build very solid, though scratch prone. The soft glossy plexiglass fronts and highly polished steel backs were just suckers for scratches. Definitely need a protector on the front and a protector case for the back. Thankfully later on, the newer designs lent themselves for tempered glass protectors ā Iāve got one on my 7th and you canāt tell itās there.
Iām also not a fan of Appleās iTunes ecosystemāwished they made it optional, so you could transfer files directly. But they did that for copyright protection purposesā¦ which ended up penalizing the convenience of those people playing by the rules (e.g. I ripped my own purchased CDās to listen to the music on my MP3 player).
Btw, while Apple never put in a dedicated LED for illumination, the iPod screens are so bright! You can really use them like flashlights.
Would you believe that despite having no screen protector for 10 years, there isnāt a single scratch on the front of my iPod? The back has all kinds of little marks though, presumably from when I put it down on the table.
Yep, same here. I just ordered my second FW3A, with 219C leds that after some checking out will be replaced by 2700K SST-20 leds, and hopefully I can McGyver some red aux leds in there as well.
The price after discount was $31.68, close enough to the announced 30 dollar for me.
I also ordered the 219C version. It is close enough to the 30$ and the leds get changed anyways. But i had no use for the XP-L leds.
The 219C will find a new home in a different light.
There should be a new batch of drivers soon, and Iām working on firmware updates. So far Iāve got the followingā¦
Fixed the bug maukka found ā hold-from-off then release-and-hold in stepped ramp wouldnāt work until it had been on for a full second.
Made candle mode slightly more calm but also able to burn a bit brighter sometimes.
Beacon mode duty cycle is 100ms now instead of 500ms.
Made muggle mode do smaller thermal adjustments.
Rewrote most of the thermal regulation code. It should significantly improve pretty much anything related to temperature, except for the lack of factory calibration. (still in progress, running tests right now) It takes a while since I need to test basically every supported light, but the ones Iāve tested so far have all waited a sane amount of time to heat up, dropped quickly to a sustainable level, and then just ā¦ stayed there. None of this oscillation nonsense from earlier versions, and so far it has managed to step down at a point which is neither too early nor too late.
Also planning to do some other misc updates, as many as I can squeeze in before the deadline. Not sure which other tasks will get done in time. The top tasks are making āholdā auto-reverse in strobe modes, making momentary do the last-used mode instead of just the last-used brightness (so, momentary strobes), and generally making muggle mode a little nicer. Also debating whether to add ten-clicks-from-off as a shortut to thermal config mode. But I wouldnāt count on any of these things.
Nice, Iāll probably end up picking up another FW3A when the new driver and LED versions are in circulation. As always, thanks for all the hard work TK!
Sounds good.
Have you thought about/ would it be possible to incorporate a configuration lock for ramp config, ie the settings for mode numbers, max ceiling & floor canāt be changed unless a code is entered like the H17F or preferably like the LD4Power drivers?
Iāve slipped into ramp config a couple of times & accidently changed settings.
Just a thought.
