They offer the best 26650 batteries available so far. If Sofirn were able to source PLB-55A cells it would be really great. These cells provide more power than Sofirn's new 26650 HD cells.
If you want to go for 21700 batteries (personally, I'd really appreciate this approach), please try to get cells like Molicel P42A or Samsung 40T for these should have the best compromise between high drain (> 15A) and capacity. Samsung's 30T would not make much sense for it has not much capacity and its benefit over the 40T would only last some seconds with a fresh, fully charged cell.
So, there actually is a custom version of Andúril that supports both e-switch and the tailclicky forward switch. If we want to have Andúril on Sofirn's SP70 BLF edition, this custom version might be the right thing as flashing the standard Andúril would normally sacrifice the momentary turbo and mode memory function of the tailclicky. Maybe Toykeeper can share with us her thoughts about it. ;-)
For my super high amp 6V lights, I've converted over to only FET. The smooth ramping is a little jumpy at the low levels, but at least works. I can fry a 7135 in seconds on those lights. Sorry, haven't kept up with the new designs, but very interested in these alternate solutions. Of course what I want is smooth ramping capability on these other designs, and smooth transition to the full FET. Of course high PWM is a must, and no PWM preferred.
My SP70 has become my nightly user, it’s an instant hit with everyone I show it to. I’ll probably pick up another if this blf doesn’t pan out, which would be a bummer. A blf version would be an automatic recommend to all the night guys. And all the camping guys. And all the guy guys. With just a few tweaks and a little price adjustment, I’d be in for at least 3 more lights.
I wish people would not phrase their questions like this. It’s very negative. Just ask how the project is going.
If you want it to be dead you can unsubscribe and forget about it.
If you want to know the truth, you have to be patient.
Sometimes projects get cancelled because they know the costs don’t make sense. Sometimes projects get put on the back burner until the company gets caught up with backordered stuff.
I’m assuming this project is still going forward, but Sofirn is working on a lot of things at once, so development is slow. They might be waiting on a new driver design to support Anduril or maybe waiting on ToyKeeper to tweak the software, etc… You just never know until they speak up and give an update. Even updates are few and far between. I just assume the project is going forward unless I hear otherwise.
As JasonWW already said, Lexel has an appropriate 6V FET driver that fits both into the Convoy L6 and Sofirn SP70. It uses the Infineon OptiMOS 5 MOSFET and can use NarsilM or Andúril for the user interface.
Sofirn has a wonderful UI (very much dislike the default ramping direction of Andúril-should go down, not up; also nice is going back from turbo is a no-brainer). I wish the BLF SP70 would work like this.
Warm light would be really really nice. And an SMO reflector.
