PM incoming
gChart :+1: on the headlamp and smart tailcap mods. If anyone has a D10/D25 or Convoy H1, I recommend a gChart MCU upgrade.
Thanks, pc_light!
PM incoming
Thanks, pc_light!
I put 219b leds in a C8, only linear driver no FET
Modded my D18 with 18x 219B R9080 45K, maybe the brightest single 219B?
I also replaced all the optics with FP13028_LISA2-M-PIN (from Arrow) which has a wider LED opening and about the same beam width, maybe a few degrees wider.
Max regulated (14×7135) :
Output: 1,212lm
Spectral:
CCT = 4686K (Duv –0.0069)
Color Rendering Index (Ra) = 95.2 [ R9 = 98.1 ]
R1 = 97.9 R2 = 96.3 R3 = 91.0 R4 = 95.3 R5 = 96.3 R6 = 90.6 R7 = 96.1
R8 = 97.9 R9 = 98.1 R10 = 88.7 R11 = 94.3 R12 = 71.8 R13 = 97.7 R14 = 94.9
Yxy: 3226.395623 0.352368 0.343720
Turbo (3x not quite full 30Q’s): 7,714lm
Disassembly:
If you pull out the optics with tweezers you might want to use the grippy kind or wrap them in tape. If it slips at the top of the optic and closes it will leave a nice scratch (don’t ask me how I know).
Thermal transfer aint perfect but half of this giant MCPCB is good enough. My carbon steel crepe reflow pan on my induction stove top prepped for LED removal.
Stand by as I flip these bad boys onto the serving plate, stick a fork in them. You can also see the ridiculous amount of solder used. Almost as much as djozz does!
Reassembly:
A few important things here. Peppa pig precision electronics brush and alcohol. The saying goes measure twice cut once? Well I learned when modding to clean 47 times assemble twice.
I didn’t add any solder paste to the +/- pads considering how much was there already but I did use a toothpick and the smallest possible amount on the thermal pad. LEDs in position with my cathode marks all saluting me and wishing good luck. I have a video of part of the reflow but i need to edit it and speed it up. Needless to say it was uneventful, once it “flowed” I gave most of them 1 good tap and several that didn’t “look” centered got an additional tap or two.
What a relief, she works. Side note, based on Vinh’s video and the wires I had to desolder on the side I thought the MCPCB needed the 2 jumper wires connected but it doesn’t. I guess that is just to help even the current load? IDK.
The shelf still had a good amount of paste so I only added a touch to the more “open” areas of the MCPCB. Hope MX4 plays well with what Emisar uses. The LED wires and jumpers soldered pretty easily with a bit of flux paste on wire ends, dab of fresh solder on tip and 410-415C setting. Emisar uses great quality wires as always.
I put the two optics next to the jumper wires in first and just went to town. Don’t forget to clean your LED domes first, use a moon setting to see if you missed anything.
The trick to getting that clear O ring back on is this: Put it 3/4 of the way around that black PCB cover plate groove then for the last bit take the glass and place it on the O ring. Press on the top of glass and keep constant pressure as you slide the O ring into the remaining groove. Now your glass is slightly off center, keep pressing and re-center it, done!
Good job. When setting the turbo, what is the value of Duv?
Nice work on the D18! My ROT66 has 9 of those leds, you got môah!
So I’m known as the one that always uses too much solder paste?
So I’m known as the one that always uses too much solder paste? :person_facepalming:
But we love your LED tests <3
Today I replaced the MCU in my Sofirn SC31. It had a PIC (or similar) and now it has an attiny412.
It’s running a custom (from scratch) firmware, tailored for use as a nightlight in my toddler’s room. MCU is sipping power by clocking off the internal ULP (ultra low power) oscillator. Once the battery is inserted, it begins a cycle of 10 hours on, 14 hours off. Single click of the e-switch temporarily overrides on/off. Click and hold for ramping up and down. At 3.00V, the aux LEDs begin to blink for LVP warning.
USB recharging probably still works, but I haven’t fully tested it yet. The aux LEDs aren’t lighting up, but I don’t know if it’s charging or not. The charging circuit is the usual suspect: TP4056. I need to check into this more. Probably need a USB analyzer to know for sure what’s going on.
Cord wrap on the LAN Mokume Gane.
Modified one of Lexel’s FET switches to be less remote. Fits fairly well in a Convoy L6 tailcap. Might be a better fit in a Convoy M21A. Giving it a second look, I could of used a spacer to raise it up a bit and the spring choice might not be ideal. Slightly limited because of the location of the FET. I also could of done a better job with cable management, but it works. The spacer used was from a remote tail switch with the nubbin cut off. I’m assuming getting a voltage reading when off is normal and not that I screwed something up. A bit of a hack job, but there aren’t a lot of offerings for these kind of switches. Lexel has started a GoFundMe for a high current tail board among other campaigns.
Changed the handlebar on my new bought Kawasaky Versys 650 to a silver ABM 230
I had this from my former Motorbike the Kawasaki KLE500.
Positioning was hard because of the fitting holes for the instruments. And there is not much space to the cassis and the windshield. I have to buy a separate mounting for the mirror, because the left mounting on the coupling is too wide away from the handlingbar and too near to the windshield.
Inspired by the D18 tint mixing. I wanted to finally give it a go.
Heard both negative and positive opinions about mixing leds.
In my case i changed two of the four 219C 5000K emitters in a D4 with two 219C 4000K.
I know that doesn’t magically make it 4500K. But i was surprised by the result. Way better than expected.
Here’s a comparison:
D4 with 219B 4500K
D4 with 219C 4000K + 5000K
and a D4 with all 5000Kall three @ turbo. all three with a Sony VTC6
Camera: Canon EOS 40D (1/2Sec - f/3.5 - ISO160 - WB 4500K)It doesn’t have the rosyness of the 219B, but in a side by side comparison it shows how much more lumens the 219C produce.
And the results were amazing (to my eyes). It’s still a little green. But the addition of some 4000K makes the beam way more lovely.
Not as pretty as 219B 4500, but close, and with more output.
Very nice! If you want to try it again, the further you separate the CCT the rosier the output
Accidentally dedomed an LHD351D by ripping off the silicone dome clean while it was hot - should mention I was pretty heavy-handed with the initial reflow (read: left the iron on the original MCPCB a bit longer than I should have) - but it survived and I decided to not waste it.
So I mounted it on my Lumintop Tool AA 2.0 and just put a tailcap bypass - simple stuff - but it keeps me sharp for the bigger boy projects that may come
Much better tint than the original XPL-HD imo -
Two copper S2+
So, I've been working on this project for a while now. As soon as I received my first copper S2+, I knew I wanted to do something special with them.
Batch 1 build - I'm technically not done with this build yet, I'm waiting for a new copper pill, but got this one working nonetheless. It's a XHP-70.2 being run by a MTN-BST2 driver. As far as I can tell, there's no donut and the light doesn't get as hot as quickly as I expected it to. I love the way this package looks.
Batch 2 build - I decided to go a different route to get to big outputs on this one. Did a triple build using 3 Nichia 219c's @ 4000k, and a CWF Dragon driver and a copper triple pill by Kiriba-ru. I decided on amber secondary LED's.
They both are run off of Sony VTC5A's (I feel like the green color is like an inner Hulk) and have the little things done like tail spring bypasses, etc. LOVING them
those are very beautiful lights.
I opened up the bezel of my short triple S2+ with the lathe at my work :
Went from 600 lumens to 700…
Today was FW update day on some of my anduril lights so I took a family pic. One more, an EA4 is my glove box light for the summer since it runs AA NiMH’s so it didn’t make the pic.
Added glow gaskets to some lights. One of these lights comes standard with a glow gasket.
It doesn’t show real well in the pic but the one on the far left closely colour matches the lighted tail.
Yesterday was a good day (today not so much) so i made another stepp to complete my heatplate. Its fully funktional now. But i have to cut a Aluminium plate to cover the inside right and left from the heatplates.
It looks scrappy. But i wanted to invest only a few bucks. So almost everything is repurposed. From the fans, the wooden bier box, the switches, the heatplates (Aluminium cooler from a dead amplifier with removed finns). I had the DC-DC converters here (bought in a lot of 10 in the past). So i only bought the heating elements, Temp controller and the cob leds. The wodden box is repurposed multiple times. I installed the fans when i used it with a old PC powersuply. But now they keep the fumes out of my nose. Hope to get the Aluminium cover made soon and then i will put a few drops of paint on the outside to make it look less scrappy. And i have to get my new powersupply ready. The car batteries voltage is not stable when i pull max ~17A. The battery was not fully loaded when i took the pics so the current readings are a bit lower.
I have 2 Temp zones. The more black one has ~50W controlled by a bimetal switch (120°C) and the main plate ~100W controlled by the tempcontroller with Thermocouple. The fan is controlled by the poti on the front. I removed the original poti from the DC-DC converter and connected the poti in the front. Leds run on ~3V @1,4A. It takes some time to get hot but it gets there and on the mainplate i can hold the temp +–5°C. I made a new wire with Banana plugs out of 12AWG wire (the red one) and i ordered a blue 12AWG to make also a new one for the negative pole. For now i use 2 of my usual testing wires to not run into problems with voltage losses.
And i got the message that Kirill shipped my new pill for the ZY-T08. I like the light and i want to put a 3V XHP-50 in it. The pill has a 20mm driver pocket with retaining ring. I will use the original sripped driver with a custom brass ring as contact plate (also with retaining ring. The threads on the outside are cut on the complete length. To improve the heatpath. Should work nice. Thanks to Kirill for making my drawing a reality.
I didn't like the diaphragm popper on the operation on the FW3A so I decided to install a proper tactile momentary switch with a smaller button and a magnetic shrouded enclosure.
Carbon fibre switch enclosure with 15 neodymium magnets, 8mm diameter linear button with 6mm x 1.5mm green tritium vial.
The button can only move in a straight line and accidental activation is not as easy now.
The carbon fibre/ magnets are fixed in place, sit flush with the tailcap edge and strong enough to hold the light horizontally.
