I am looking for a foil that can be cut and labeled using a plotter.
So for example use a permanent marker to write some stuff on then cut it out to create a quality looking label.
I know some labeling machines work ok, but I am looking for something that sticks better and has a higher quality look.
As far as I know not every glue is fit to be used on the aluminium hosts from most lights. (looking for something to stick on a Thorfire TK15S)
Have seen some Oracal (for example 951) foils that sound like they could do the job, but unsure if those can be written on.
Really looking for something permanent, labels from labeling machines tend to get loose after a while.
Does anyone have experience with this and has good suggestions for a foil and a pen that can be used in a plotter?
(can 3d print pen holder, just need a pen that sticks to the foil)
