My timing was extremely low tech, a digital stopwatch. :person_facepalming: . Highly unscientific or accurate but it was the best I could do. My badā¦
. EDIT:
Yep, sure looks neutral white to me. It was pretty clearly stated in the product details page. And itās a good rendition of NW, too. Iām really happy with it. I donāt get how some people are all bugged out about all their lights being warm Hi CRI. Itās nice to have some varietyā¦ The thing to avoid is screechy ice blue. The nasty of 6500K LEDās past. Yuck.
Is there a way to reset the Anduril UI to factory defaults ?
For some uknown reason , double click (from OFF) doesnāt seem to enter Turbo , or other shortcuts (battcheck , lock out etc ) (edit: with triple/qud click etc) .
I have been using mine for a while now, and after the initial problems with dirt etc, everything has worked well. I am now using 35Eās instead of 30Qās as I donāt need scary bright for 10 seconds
I find I prefer the 7A to the 3D given the choice. I am liking this flashlight more and more and even used candle mode last night. I have also got a 219c on order and am definitely in for any copper versions in the future.
All in all its a very good flashlight that has taken over from my Emisar D4s (for now :-)) as my goto light.
Thanks very much for all the effort that has gone into this.
Received my 3D and 7A, both DOA. Followed troubleshooting but no luck reviving them. Havenāt given up yet but the chances seem like theyāre gettting slimmer.
Really wanted to try Anduril but doesnāt seem like a good trade off for reliability. Guess flashing the D4 is my next stop.
Ok so I did do a side by side comparison and to my eye the eo3h is slightly warmer, so Iād say youāre right with your guess at 4000k.
I definitely have to say though, @ToyKeeper did a stellar job on the iu,
I canāt stop playing with it,
Now that Iāve slept on it Iāve realized that a significant part of my disappointment is that candle mode doesnāt look that good in a neutral white tint,
Though I did have some lighting gells laying around,
I wonder if a piece of CTO can fix thatā¦
One dead flashlight, manufacturer error. TWO dead-on-arrival? You must be doing something wrong. Cheack the troubleshooting thread. Maybe your batteries are too long.
Please list details of exactly what you did, known good batts, etc., maybe we can help. I got the 3D and 7A and one was DOA but the driver retaining ring was loose - tightened up and never gave me a problem again.
Well thatās a bit of a mystery. I run my light in stepped ramping (not smooth). When I switched to muggle mode, it showed smooth ramping instead of stepped. Triple click would not switch from smooth to stepped. When I took the light out of muggle mode, it remembered that primary mode was set for stepped ramping. So Iām really puzzled how you got into stepped ramping while in muggle mode.
Inclined to agree itās operator error, but one shows no life and the other immediately goes to 100% with no control as soon as threads make contact. Iāll be continuing in the troubleshooting thread as my details are already posted there, unless I run out of options. Then Iāll be back to cause trouble here.
Two known good 30Q, cleaned threads, tightened tail cap in order, both retaining rings tight on arrival, loosened then tightened both to confirm driver alignment, disassembled and reassembled switches, checked and cleaned switch contact tube, swapped heads and tails between bodies. Problems follow each head - one has never illuminated with either switch and tube, x the other has always gone to 100% with no control.
