Right. Considering this was a PRE-ORDER & you were toward the end of the list at numbers 2106 & 2107, a month is not bad at all…. and not even close to “the end of the world”. :+1:
If you can unsolder the two wires the new MCPCB comes with & the two wires on the FW3A MCPCB, swap the MCPCB’s & resolder the two wires in the FW3A on to the new MCPCB… your good to go.
With the release of the nichia version, does this mean the SST-20 version is dead or delayed further? I prefer the SST-20, but would buy the nichia version if it’s confirmed that it’s replacing the SST-20 that’s been hard to source.
Anyone else seen a tracking showing returned to shipper? Mine shows shipped on 05-20-19 and then "Returned to shipper" 05-22-19. I emailed Neal but haven't heard back yet. I'm more patient when I'm not confused...
My first one arrived almost two weeks ago… The second was hung up in tracking… Mind you they were ordered minutes apart… Now DHL gives me this :
We wish to inform you that a number of packages may experience delayed or missing tracking information. Continue to check this tracking page for the latest update. Please accept our sincere apology for any inconvenience this may cause.
I take that to mean the Nichia version is as well as, and not instead of, the SST-20 version, and does not impact the production of the SST-20 version.
Yeah, it’s usually easy enough to figure out the revision based on the light’s behavior. A useful version string would end up being very long and difficult to read.
Then you’re in good company. Most of us are idiots around here. At least, I know I’ve done some pretty dumb things…
Those are 8A cells, which is certainly plenty for the regulated modes. 7x7135 chips should max out at 2.5A, assuming they are 350mA chips.
I don’t know what the max current is on turbo, which is pure FET driver. I would guess it’s pushing around 8A with a full battery, less as the battery depletes. Anyone measure it? IIRC, I think the max discharge of the 35E is rated at 13A, but that would be for brief periods.
Given how quickly the light will ramp down on turbo, I doubt the battery would be draining more than 8A for very long, if at all. So the 35E should be fine. Or, you could go with a Sanyo GA cell (10A) which gives you some margin. Personally, I wouldn’t worry about it, though.
The only thing I’d stay away from are older low-drain cells, like the Panasonic NCR18650B.
