This seller has M14 washers which are 14mm inner diameter so a bit big but the outer diameter is 22mm so close to stock and its 1.2mm thick. Seeing as they come in a pack of 10 you could get a second one and cut a ring out and create a ridge on another washer by melting them or gluing them together? You could even glue in another washer of a smaller size to make the inner diameter correct.
My light did not come with the instructions. What is the discreet mode level? If I changed into that mode instead of ramping, will I get turbo in the mode sequence? I would just like turbo to be top of ramp or in the mode sequence to I can have brightest mode with a single click from off. Is this possible with this light?
I implemented the top of ramp being less than max on request, but I don't use it myself. I'm not sure why it was used on this light, guess TA had his reasons.
From OFF, dbl click will get to full max though - Anduril doesn't work that way.
Thanks for the instruction manual. I changed the ramping to mode sets. But I don’t like that ui so I changed it back. It’s like having a forward clicky but with a side switch. Kinda funny to have to click each time to change modes. And you can’t change modes after the first initial couple seconds.
You actually can change modes after it gets locked in. You can press and hold the button which changes the brightness level as well as unlocks things. Say you have it set to 6 total brightness levels and your on level 3, but you want to bump it up to level 4. You press and hold which drops you to level 2 and then you click normally to 3 and 4. It’s a bit convoluted.
I have issues with my light - at first, I thought it was a thermal thing and I changed the settings.
Now it seems it rather step down due to low voltage.
If I insert a 26650 Shockli at ~4.05V it will step down in brightnes from max after 8s and then step down 3 more times each ~23 seconds.
With a 18650 VTC6 at ~4.15V, it also steps down after 8s and continue going down.
The flashlight is useless like this.
BG wants to give me like 1000 points - can’t use it on already discounted items so sort of useless to me.
