no i dont think nichia rules out the sst20, last i read here they are still working on getting it or something.
Yeah.
The SST-20 is throwier, has better color rendition, and has the same efficiency, and is actually cheaper to get.
Is this yours?? Or you just posting a picture you found somewhere??
someone should hit the rude button on this person for posting this picture :wink:
:+1: . /\ ā€¦ :smiley:
Post #11009:
I take that to mean the Nichia version is as well as, and not instead of, the SST-20 version, and does not impact the production of the SST-20 version.
Yeah, itā€™s usually easy enough to figure out the revision based on the lightā€™s behavior. A useful version string would end up being very long and difficult to read.
Then youā€™re in good company. Most of us are idiots around here. At least, I know Iā€™ve done some pretty dumb thingsā€¦
Thatā€™s a pic from Neal. Itā€™s a FW3C prototype sample.
Iā€™m hoping the production version can be polished or even just raw to improve durability and give it more of a classic copper look.
Nope, not mine. Iā€™m not fortunate enough to have such good connections. This was posted on a FB group, and was originally posted on reddit.
/\ . :+1:
Sandblasted Ti body and tail + raw Cu head
Is it ok to dream?
so 35E batteries are the best if u looking for best runtimes yea ?
Those are 8A cells, which is certainly plenty for the regulated modes. 7x7135 chips should max out at 2.5A, assuming they are 350mA chips.
I donā€™t know what the max current is on turbo, which is pure FET driver. I would guess itā€™s pushing around 8A with a full battery, less as the battery depletes. Anyone measure it? IIRC, I think the max discharge of the 35E is rated at 13A, but that would be for brief periods.
Given how quickly the light will ramp down on turbo, I doubt the battery would be draining more than 8A for very long, if at all. So the 35E should be fine. Or, you could go with a Sanyo GA cell (10A) which gives you some margin. Personally, I wouldnā€™t worry about it, though.
The only thing Iā€™d stay away from are older low-drain cells, like the Panasonic NCR18650B.
Is there some estimation how long the FW3A will run on the lowest moon mode, for example on a 30Q cell?
I think the continuous discharge rating is pretty irrelevant. Itā€™s more of a way to compare batteries and not so much a way to match a battery to a light. You are taking it way too literally. Itā€™s kind of a subjective number, so donā€™t pay too much attention to it.
The best runtimes might be from the Panasonic NCR18650B, assuming you donā€™t care about measuring the Turbo output. The 35E and GA (and MJ1) are also fine cells for this light.
Iā€™d rather have full Time. Even if that means the fet is turned off by default to protect the LEDā€™s.
Has anyone baked one of these yet .
That light in a bag looks like maybe it was done in the microwave. you know how they tell you NOT to cook in those plastic bags .. :P
The light in the bag is a prototype FW3C, made of copper.
Copper isnā€™t really my thing, but I do like titanium and Iā€™d probably buy an FW3T. Yes, I know the thermal properties are worse.
Titanium with a copper shelf section like the D4Ti would also be fun.
I wish neal could find out what happened to my #2ā€¦ ordered at the same time as #1 - which arrived two weeks ago
