I think this is SST-20 4000K 95CRI, which runs hotter and less bright than the lower-CRI versions. Just checked again, and it’s definitely around 4000K, so it’s not the 5000K 70CRI version.
This high-CRI version is only supposed to make about 10,000 or 11,000 lumens, but I measured it at 13,900 lm at start with a set of just-charged 30Q cells.
This was measured with an integrating tube, so it’s not as accurate as a sphere… but it’s pretty close. I used some biased diffuser sheets to improve the integration qualities, then calibrated it to match reference lights from maukka. The sheets force the light to spread out and bounce around inside, so it’s less favorable to throwy lights. It also acts as sort of like one-way valves, which reduces the impact of the entry point and initial bend, so it gets more consistent readings for a wider variety of lights. But it’s still not as good as a sphere.
Anyway, I think it actually could make 14,000 lumens with some high-amp cells like 25R. And more, when using lower-CRI emitters. Just not for very long, because it gets hot fast.
This Astrolux MF01S looks very similar to the Emisar D18, as both use 18x SST20 emitters, and both use Anduril firmware.
Just curious what would be different about this MF01S compared to the Emisar D18? The D18 uses 3x18650, so the batteries have to work harder to put out higher lumens (need to use very high-drain 18650s on the D18), whereas the MF01S uses 4x18650 so the current drain per battery is notably less. (I’m assuming that the higher max lumens on the MF01S compared to the D18 is mainly due to the MF01S having 1 more battery to drain current from).
I would presume the MF01S, having a 4x18650 body, may have a bit more thermal mass so heat may be able to dissipate a bit better — at around what lumens does the MF01S stabilize (it seems to be nearly 2000 lumens from the above graphs), doesn’t the D18 also stabilize at nearly 2000 lumens?
How about in terms of beam pattern, I’m curious how the MF01S compares to the D18 (the D18 has a focused spot, corona and useful spill area of light).
I think TA meant the D18 sustained output was tested with 70CRI emitters whereas TK tested the MF01 with 95CRI emitters so you can’t directly compare these sustained outputs.
This was not a test for highest sustainable lumens. This was a software test of how the driver handles heat. Two different things. So I would not make assumptions.
To test max sustainable lumens you start at a certain lower lumen level and see how the light behaves. Temperature will build up much slower which may or may not activate the thermal management and you should get different results.
It will probably be in the same 2,000 to 3,000 range, but probably higher than what the tests above show.
My point is you should not jump to conclusions. Recognize what is actually being tested. (I might be grumpy today)
