FREEME ✌ ASTROLUX FT03S SFH55 9300lm & FT03 SFT40 2200lm 1300m NarsilM v1.3 USB-C - ALIVE
My light did not come with the instructions. What is the discreet mode level? If I changed into that mode instead of ramping, will I get turbo in the mode sequence? I would just like turbo to be top of ramp or in the mode sequence to I can have brightest mode with a single click from off. Is this possible with this light?
I think it’s possible in mode sets, but not ramping.
You can also set the modes to reverse order so 100% will be first and it cycles lower.
If you turn off memory, 100% will always be 1 click.
I don’t have the instructions for this light either, maybe someone can post it or link to it.
http://img.banggood.com/file/products/20190129202400FT03usermanualdraft04withadvancedsettings.docx
Would make a PDF but on mobile :slight_smile:
I implemented the top of ramp being less than max on request, but I don't use it myself. I'm not sure why it was used on this light, guess TA had his reasons.
From OFF, dbl click will get to full max though - Anduril doesn't work that way.
Replied.
I have placed the order, thank you freeme!
Just making sure that subscribers of this thread know about the potential holster HERE. I didn’t notice it at first.
I’d like the code
Thanks for the instruction manual. I changed the ramping to mode sets. But I don’t like that ui so I changed it back. It’s like having a forward clicky but with a side switch. Kinda funny to have to click each time to change modes. And you can’t change modes after the first initial couple seconds.
You actually can change modes after it gets locked in. You can press and hold the button which changes the brightness level as well as unlocks things. Say you have it set to 6 total brightness levels and your on level 3, but you want to bump it up to level 4. You press and hold which drops you to level 2 and then you click normally to 3 and 4. It’s a bit convoluted.
I definitely prefer ramping mode myself.
Mode set operation in Narsil are based on the "Werner UI", which many preferred at the time.
I have issues with my light - at first, I thought it was a thermal thing and I changed the settings.
Now it seems it rather step down due to low voltage.
If I insert a 26650 Shockli at ~4.05V it will step down in brightnes from max after 8s and then step down 3 more times each ~23 seconds.
With a 18650 VTC6 at ~4.15V, it also steps down after 8s and continue going down.
The flashlight is useless like this.
BG wants to give me like 1000 points - can’t use it on already discounted items so sort of useless to me.
Any advice?
Have you pulled the MCPCB and checked that it’s smooth on the bottom? Wonder if there’s poor thermal transfer and it’s just throwing a fit.
With all the mechanical sounds it made the first times I was sure it was purely a thermal thing. But I can’t even run a “medium” setting on 4V - it drops down.
With a 26650 fresh of the charger I get minutes at max at least.
It would not be due to poor thermal transfer as the driver has the heat sensor. If no heat gets to the driver, it thinks it’s running cool.
It sounds like electrical resistance. Let’s say you have dirty or oxidized threads between the battery tube and head/tail or between the driver and head which is causing a 1 volt drop. Under load the voltage goes even lower which should activate the low voltage protection. This would happen regardless of what battery is used.
What voltage does it blink out when you do a triple click?
I would clean all the threads and the bare aluminum contacts around the battery tube, battery springs, driver, etc…
Also, what changes did you make to the thermal setting? You can also temporarily disable the thermal stepdown just to eliminate that.
I believe thermal step down just drops the output, while LVP blinks 2 or 3 times, then steps down.
Banggood, like most companies, try to settle issues as cheaply as possible before having to actually replace an item. If cleaning all the contacts doesn’t fix it, then you just refuse Banggoods low offer and demand a replacement.
It should be no problem to charge an 18650 with the adapter right?
Have you triple clicked to see what the driver is reading the voltage to be?
ordered 5700k. the 5000k is sold out apparently. Thanks for this one. I actually don’t feel guilty this time. so good, yet so cheap. reminds me of my first girlfriend
Should be fine. I don’t remember the charge rate. It might be a little high for certain 18650’s, but should not cause any problems.
The FT03 charges at nearly 2A, so it will be safe enough. If you would normally charge your 18650 at 2A, then it will be fine charging in the flashlight. I tend to charge 18650’s at 1A unless I’m in rush, but I won’t be using 18650’s in my FT03 anyway.
Oddly enough, the FT03 is actually the fastest charger I own…
