Very true. Back then it was awful and really was a terrible experience. But now it doesnāt seem like it was all that bad since one tend to forget how bad things were long ago.
I wonāt even go to how āinterestingā it was getting shot by rubber bullets or how fast one can run when being chased by people with big clubs who had legal authority to use them :weary:
I figured that since the front bezel FW3A is attached using external screw threads on the body, unscrewing the bezel wonāt affect anything internally. The counter-clockwise rotation to remove it might cause the front glass to rotate for a small amount, but the optic definitely doesnāt move. I pop it out, then put a replacement optic into the 3 peg holes, lay over the glass, then screw down the bezel. Nothing internally rotates. But I hear you, that it may not be true for every assembly.
I will follow your advice, though. The next time I do it, Iāll take a toothpick to the MCPCB and check to see if itās well anchored in place or loose. I definitely donāt want to end up torquing the wires and cause them to detach!
Heyā¦ if you have not had any problems your obviously doing it right. I wouldnāt change anything. (And I did not suggest a ātoothpickā for anything eitherā¦ )
All I am saying is just because you have not experienced a problem does not mean someone else will not experience it.
I have found that a little bit of pressure on the glass lens with my thumb when removing or tightening the bezel on lights where the MCPCB can rotate is enough to prevent a problem. (after the first time I ripped the wires loose on one)
I have double check to make sure iām not in muggle mode.
Iām unable to go into Group 2 now.
When i perform click, click, hold ā¦ā¦it just respond by one dim flash/flicker and goes off.
Iām able to go into Group 2 the first time when i received this light and i was playing with all the Group 2 mode (candle, bike flasher, party strobe, tactical strobe, lightning storm). The last Group 2 mode i used was lightning storm.
About the wires getting ripped off by rotation, Iām guessing that isnāt usually an issue for people who change the optic, since the thermal paste is already stiffened up by the time they open the light. It might be an issue at the factory though, when the paste is still fresh and moves freely.
It might just be that lightning storm mode doesnāt feel like making any big flashes right away. After the dim flash, try leaving the light alone to see if the lightning continues. Or, after the dim flash, try to click twice to see if it goes to the next mode.
By the way, how does one adjust the party strobe to āfreezeā things, such as falling water and ceiling fans? Is it just trial and error? I donāt mean how to button press to make changes, i got that part, I mean what frequency works, slower/faster.
ā¦ just change the speed until it looks good? Itās not a science; itās more of an aesthetic thing. As a general guideline though, typically the ideal flashing speed correlates to the speed of the thing being viewed. Faster-moving objects tend to work better with faster strobe frequencies.
i mean it would be different if the flashlight had some way to tell you its strobe speed, then you could tell the speed of rotating objects, but it doesn;t do that, so anything āworksā - itās just fun and games
Very strange. Iām not sure what could cause this. Do all the other functions work, like battery check and temperature check? It fully ramps up and down?
