Teacher and all,
Here are the pics , after the pic of the knife closed the next ones are knife #2.
Please understand I am not a knife guy per se, Have maybe 15 but really like this knife and don’t want to give wrong impression that is not a wonderful knife because I believe it to be.
I got clamped by lock failure when I was like 13 by trying to carve name in a tree and was pushing hard trying to dot an “I” and it closed on my fingers, was lucky did not sever ligaments so that is why I am paranoid of good locking mechanisms.
Now you know why I never ever ever push/pull/crank/twist/anything on a folder. Just got a coupla more cheep fixed-blade knives for s&g, and for when I might have to do something like that.
I never had a folder unexpectedly close on me, but my old Buck(ish) lockback had a sort of hair-trigger. One wrong “lean” trying to push “backwards” (ie, not into the cutting-edge but against the spine) and yeah, it could’ve easily collapsed shut and tried taking off a coupla fingers in the process. Noooooo thanks.
That lockup doesn’t look ideal, I have a Kershaw Leek that’s similar, but it’s a frame lock and probably sturdier, and you do put pressure on it since it’s on the outside when you grip….that one does look a bit iffy tho…maybe try those spine whacks tests with some thick work gloves on, or keep it for light duty stuff like mail and package opening if you feel it may fail, the width of the lockbar that engages the tang is quite wide for a liner lock, kinda weird, looks more like a frame lock.
Thanks for the info lightbringer, right now I’ll just be withdrawing my balance and if I use paypal it will just go through the bank. I’m guessing they weren’t making enough money the old way(seriously?) so they scrapped it
There is something else that looks slightly different to… but I can’t put my finger on what it is. :person_facepalming:
I've loaned my camera to a buddy but I am gonna get it back & take some closeups that match yours & see if I can tell if their is a slight difference or I'm crazy. … The safe bet is on crazy.
Personally, I would have no concern over using either of those. ’But’…. that being said, I only cut with my knives. I do not use them as a pry bar, screwdriver, hammer, or chisel…… I cut with them.
I might take a bit more liberty with a fixed blade if need be…. but not much. Unless it is an ESEE 5 or 6 of course……
I think with a bit of opening & closing your two will wear in & be just right.
However…. If you want to be rid of them I will be glad to buy them.
I can understand your pause after reading your story about “dotting the i ”… . :person_facepalming:
I only found 2 knives in my stash that have a similar interior liner lock that looks like a frame lock(I’m referencing the 3rd pic on page one of this thread, and the cutout in the liner lock that is opposite the middle scale screw), a Gerber and a Kershaw Link, but all the liner locks are much thinner, this Gocomma is the thickest interior liner lock, is it a heavy knife?
Just mentioning this for Muto, looks like it would be hard to make that lock fail with that thick gauge.
Edit… I forgot to answer your question about “heavy” Blackbeard. I don’t consider either one overly heavy. They just have a good solid feel, if that makes any sense to you.
The one pictured above has a more solid feel to me than the FH-11. And… “it will cut” … as well as hold an edge.
Speaking of locking mechanisms, here is a pic of the lock on my FH21. Being new to folding knives and this being my first one, I don’t really know if it’s good or not, but there seems to be a good amount of overlap.
The only way to feel the quality is by fidgeting with it, not by looking at pictures of the position of the locking liner.
But on the pictures you can see that most knifes don’t have a symmetric grounding and this is far more important for a knife. Almost every reviewer don’t even look at this…
Looks fine Pete. :+1: . And like Omega_17 kinda said…. it’s all really about the geometry of how the lockbar meets the angled part of the blade heel. If the geometry is right, the lockup will be right.
And your pic looks great to me.
If Muto feels like his lock up is questionable then he ought to be saying so . I feel like mine is questionable too and am happy someone mentioned it .
If anyone (in the USA) wants to be rid of what they consider a “borderline dangerous or crappy lockup” GoComma, please PM me. I will be more than happy to purchase it/them from you. As long as you have not attempted to sharpen it/them.
Sorry Teacher but you saying that you're willing to buy them may sound impressive but has no bearing on whether these knives are any good or not .that's just a fallacious argument .
Someone may say an atomic beam is a great flashlight and then offer to buy them from anyone who doesn't like it ...doesn't mean a thing .
When the whole locking liner has contact with the lockface on the blade and the blade won’t close with a spinewhack then it’s safe.
Try to understand how a liner lock is working, tell why you feel yours is so unsafe.
A folding knife is by definition a broken knife. But they can be safe if you are not a idiot. A locking mechanism is a very recent feature, for example the liner lock was only invented in the 80s.
Basically… I doubt very seriously you know what you are talking about Boaz.
Have you even tried to make the lock on yours fail to actually prove what you are saying?? Or are you just posting speculations??
I have, on five (5) of the ones I have left. No lock failure at all. All 5 solid as a rock. And I tried hard to make them fail.
There is nothing to “defend” and ego has nothing to do with it. I am also not insane.
I also do not buy “crappy knives”.
I could surely be wrong… but I am betting I have quite a few more than you & know a few more makers than you too.
I’m not trying to “prove” anything…. are you?? You might want to check your motivation…… especially if you have not even tested yours to see if you can make the lock fail. Cause if you have not, you are doing nothing but spreading your opinions as fact.
If that offends you I hate it. Test your knives honestly & honestly post the results…. not just your ‘opinions’.
Oh yeah, as I posted last night; open the knife rather hard several times. On a new knife such as these, there is a very good chance the lockbar will move to the right a bit.
