[M4D deal] Convoy L21A / M21A groupbuy
Hello my dear friends!
Today i present my newest groupbuy:
(links in the pictures take you to the shop for more info)
Convoy L21A $32.99
SST40 2300lm 6500K White Tint LED Torch 21700/18650 Flashlight
My CODE: ML21A your price: US$ 32.99 (45.99)
Specification:
Name LED Flashlight
Brand Convoy
Model L21A
Material Aluminum Alloy
LED Luminus sst40 6500K white tint
Lens type Ar-coated glass lens
Reflector Smooth
Battery 1x 21700 or 18650 lithium battery
(Battery not included)
(It is recommended to use original 21700 battery from Samsung, LG, Sony, or Tesla.)
Mode 4 modes 0.1%-3%-30%-100%
Max current output 6000mA
Temperature protection management inside
Lumen 2300Lumens(Max.)
Range 720Meters(Max.)
Length/Diameter 179mm / 64.5mm
Weight 540g
Tailstand Yes
Mode memory Yes
Reverse polarity protection Yes
Low voltage warning Yes
and the:
Convoy M21A $19.99
SST40 2300lm 6500K 21700 18650 Flashlight White Tint LED Torch
My CODE: MM21A your price: US$ 19.99 (28.99)
Specification:
Name LED Flashlight
Brand Convoy
Model M21A
Reflector Smooth
Head diameter 44.5mm
Height 155.8mm
Body diameter 27.3mm
Tail diameter 31.3mm
Weight 168g
Tailstand Yes
Mode memory Yes
reserved
Nice knurling (or should I say “knice knurling” / “nice nurling” :stuck_out_tongue: ) on that M21A!
M21A shows (2) braided springs!
So those are the 21700 versions of L2 and C8+, right ?
Oh wow, very much interested in the L21
mostly yes
Ordered 2 x M21A
Thanks for the great price!
1 Ordered, thx. :smiley:
I received an OUT OF STOCK notice from Banggood for the two M21A that I purchased. :rage:
their system says: Expected on June 20, 2019
maybe the order system offers you to cancel to avoid log waiting (that often collides with the presales)
do not cancel - tell them you want to wait
Yes, that’s what I did.
Thanks
Ordered 1 m21a. Thank you Martin!
What would be the best 21700 battery for the m21a? And the best place to buy it?
I bought some purple Shockli 21700 4500mAh high drain, (received them today) i will let you know if it works ok with the L21a when i receive it
Thank you!
Very tempting! Any chance of including the M21A host?
Has anyone done a review on the m21a? Also, I’m curious to know what the throw is.
I’ll probably take an L21A later this month… But just to mod it to a white flat.
Ok, received the L21a today and the shockli cells do NOT fit the L21a !
Drat, now i have two brand new cells which do not fit and have no use for.
It seems the diameter of the cells is too large. With my caliper i measured the inner diameter of the tube which is 21,5 mm.
The shockli cells have a diameter of 21,7 mm.
