Interested!
Can’t see pictures…
Preparing now.
Sent.
I would have preferred that they have kept the current knurling pattern which looks better IMO, and not added a central part like if 2 short tubes where connected with a threading.
Nice to see a carrier with top and bottom aluminum plate instead of the heavier brass ones which oxydize.
Great, you sent by Message? or E-Mail? twice nothing incoming…
Preorder placed (#3).
1 set of 3 planned.
Thanks freeme order placed.
I don’t understand the utility of the plate of the battery carrier, and I would have liked tha carrier in brass like that of the mf02.
Thank you. Placed an order.
I ordered one.
Thanks freeme.
Order placed, thanks…
The connecting plate will sit in between the two battery carriers.
Ordered, thank you!
Why freeme?
Interested!
interested, thanks.
I am interested as well. Thank you
On both ends of the battery carrier there is a white insulation piece that is protruding. If you put 2x carriers in serie, these protruding part doesn’t allow the electrical continuity so you will need the additional plate that is designed to make this continuity.
Interested
