One of each please.
I just did a quick count and there is at least 76 “yes I’ll get one” or 2, so I’m wondering if they will have enough made at this rate? - but I guess they were feeling the waters to see if they could get at least 50 people interested to make it viable.
And this is not counting those who already placed their order on their website.
yes that’s a good point
Yes, I’ve already place my order for a full copper version. I didn’t want to miss out. He said both are limited production. Hopefully the group buy price is low so I can buy another.
is it coated ?, i want it always be shinny
What’s the word on the pre-orders? Is that still a thing?
Interested depending on price.
Which emitter would you guys choose from what’s available?
Lund1660,
I picked the xp-l hi 5000k. This means you can run any battery you want. Might be swapping in Samsung LDs in but if you wanted high CRI the Nichia and SST-20 require you to use a battery that has a low current, 10A, and 20A respectively. The 219B is a rare led, so it was tempting, but the cell depenance seems scary.
Already placed my order for a Ti/Cu.
I am interested in (1) CU and (2) Ti / CU RAW please.
This is simply not true. A Samsung 40T for example can safely run the SST-20 version. Between the voltage sag and peak amps an SST-20 can support it simply will not be in too much danger. The 219B you might want to be a bit more conservative but it could easily support 20A.
I am in for one of each.
Robert
Okay
Ti+CU interested
Interested in one of each
Look like there is no clip for the full copper one(groove missing).
Nice catch. Well you probably wouldn’t want to carry it all day anyway. Mine will be on the shelf like a piece of functional art.
I didn’t check FireFlies website since they added new pictures and the pictures in OP and the one contactcr put in his message weren’t showing. My VPN is blocked and can’t access FF’s website.
I don’t like this protruding boot and the press fitted retaining ring doesn’t make the change easy so I will probably not buy it despite my “interest” for the Cu+Ti if there is no option to have the old one mounted.
