I just checked the list does not appear that my additions from post #639 have been added.
Wait, you mean a total of 40 LEDs?!
Damn that’s a lot, haha.
Yep I meant it, and it is a lot
Going to replace a few. I stopped counting at around 100 lights and that was quite a while ago. ( I also tend to fling a few into the ether - never to return - when I reflow)
Springs weren’t on the list either
Wait, you meant 30 additional springs of each size too?
BlueSwordM,
Have you concidered looking into the 4500K or 5000K SST-40’S. Those are so hard to come by. Maybe you could start an intrest list to see if it goes anywhere.
:person_facepalming: :person_facepalming: :person_facepalming:
I give some away and there is some waste :weary:
Please put me down for 10 SST-20 4000k FD2s.
I’m listed twice on the interest list (lines 3 & 15). Please update my totals to:
20x FD2
10x GA3
Please confirm that the 3500k you have are still GA3.
Thanks!
They’re still the same LEDs as before, as I haven’t ordered any more, so yeah, still GA3.
Ok, now you are just messing with me. You have me on the list for the original 20 leds and the on the list again for an additional 40 leds plus the springs.
If you delete line 4 and keep line 11 it will be right
Oof:
Let’s go to my 3rd thread for better overall seeing:
Thanks! If it’s ok then, I’d like to update my entry to include 3 x SST-20 3500K.
Got my springs today! Yay!
Question - does it make sense to “nest” them in something high-drain?
Yes.
Niiiice. Should I bend in the top bit like you have there?
Hoping to get the MF01 finished tonight…… FINALLY
oweban, those are either Gen 1 or Gen 3 springs. BlueSwordM seems to have indicated they are Gen 3, which are the same five coil design like Gen 1 springs, with also the top edge bent in as you see. Your Gen 2 springs were a different design, with only four coils and not bent in at the top. It has already been said that the top edge not being bent in can cause trouble by grabbing the cell and causing a gouge. So, if you feel like you can pull it off, go ahead and bend them in (and a little bit down). As far as I know, nobody has attempted that with Gen 2 springs. So if you try it, let us know how it works out!
Ah, I missed that - thanks for the advice! I’ll give it a shot - bought 10 of each and only neeeeeed 4.
The 1st gen and 3rd gen are the same basic design, except for a few tweaks.
The 2nd gen are different in the fact that I removed a coil from the large spring.
Not my best idea, since that made the mechanical properties worse.
All good - as suggested, I’ve bent the top coil in and pressed the end down a bit, so it’s smooth.
Got my springs today thank you!
