Aurora SH-034 Triple Nichia 219C - LD-A4 - 16500 - ILC-0 Lighted Switch
10 posts / 0 new
CRX
CRX's picture
Last seen: 2 weeks 4 days ago
An old classic revamped. This stainless steel light has a nice feel to it and is solidly built.
Aurora SH-034 - Triple Nichia 219C 5000K - LD-A4 6A - 16500 - Green Rv Clicky Sw - 1970lm.Stainless steel body
Triple Nichia 219C 5000K emitters
L4P 3XP 20mm DTP copper MCPCB
Carclo 10507 optic
Green GITD glow disc
ARC glass
LD-A4 6A driver
ILC-0 Aqua blue illuminated tailcap switch
Copper & aluminium pill
16500 cell compatible
Length – 87mm
Width – 23mm
Weight – 121g (with 16500 cell)
Max DD – 1970lm - 25s/ 580lm - (65°C)
Max 6A – 1450lm - 30s/ 550lm - (65°C)
Max 4A – 1070lm - 67s/ 380lm - (65°C)
Mode 2 - 377lm
Mode 3 - 130lm
Mode 4 - 24lm
Mode 5 - ML
The pill has been shortened, a copper centre slug installed, sheet copper lined and brass driver ring soldered.
A strip of copper tape on the outside to keep the MCPCB centered and silicone cube against the internal driver.
Copper 0.3mm disc soldered onto driver contact. 22AWG silicone wire is used.Aurora SH-034 - Triple Nichia 219C 5000K - LD-A4 6A - 16500 - Green Rv Clicky Sw - 1970lm.
I used 2.5mm copper wire to make a ring and other flashlight parts to make another screw in collar.
Felt strips in the battery tube to stop any rattle.Aurora SH-034 - Triple Nichia 219C 5000K - LD-A4 6A - 16500 - Green Rv Clicky Sw - 1970lm.
Aluminium switch housing was filed out, copper lined, transparent washer glued in place and brass ring soldered on with spring.
The rubber boot surround has an extra angled stainless steel insert and the boot itself has black silicone in it to give more of a lighted ring effect.Aurora SH-034 - Triple Nichia 219C 5000K - LD-A4 6A - 16500 - Green Rv Clicky Sw - 1970lm.
Complete.Aurora SH-034 - Triple Nichia 219C 5000K - LD-A4 6A - 16500 - Green Rv Clicky Sw - 1970lm.
Edited by: CRX on 10/21/2018 - 10:12
gchart
gchart's picture
Last seen: 3 hours 18 min ago
Beautiful!
Slayer1
Slayer1's picture
Last seen: 1 day 7 hours ago
Another awesome build!!
pinkpanda3310
pinkpanda3310's picture
Last seen: 9 min 44 sec ago
Sweet build Thumbs Up How come you used LD-A4 and not LD-B4 ?
CRX
CRX's picture
Familiarity I think. I haven’t used the LD-B4 before but going to try that setup on another light.
Geuzzz
Geuzzz's picture
Last seen: 1 hour 8 min ago
Verry nice. Especially like the ring tail switch lighting.
CRX
CRX's picture
Yes, I’m not really fond of the whole lit tailcap boot, too much. I like this effect better.
Ryley
Ryley's picture
Last seen: 1 month 4 days ago
CRX where did you get that pocket clip?
CRX
CRX's picture
From a knife, can’t remember which.
gchart
gchart's picture
Reminds me of the old Convoy clip, but smaller
