5 of each spring type and 10 sst20 please
10 SST20’s please! 5 large and 5 small gen 3 springs as well.
Thanks
I may be having a daft moment but wouldn’t reversing the direction of the wind then cause gouging when removing the tailcap?
I see.
Some further ideas:
- You have a strong material on the inside and weak on the outside. Mechanically the opposite would be much better.
If you started with a thin solid copper wire and then plated it with LOTS of beryllium copper, the spring would be much stronger.
Or, better, start with a slightly thicker (but still thin) solid copper wire and plate it with a little less beryllium copper. You would retain mechanical properties while improving mechanical properties slightly.
I know.
This would be crazy expensive.
But….
What if you started with thick C17500 spring and reinforced it with 20+ µm C17530? Would that be even possible? Would 20 µm be enough to make the difference? - Have you considered reducing contact resistance with the help of contact plates? Would that make sense?
Well, maybe. The reversing of the tail-cap might cause a reverse gouge. But then, when you’re loosening the tail-cap, you are also relieving the pressure of the spring against the end of the cell. So, it might not be as bad as when you’re compressing the spring.
All that aside, BlueSwordM will be making the new generation springs without a loose end to damage cells. The end will be bent inward.
I use a 30 caliber gas check soldered to my springs to prevent damage and to provide maximum contact with the cells in high current lights.
1. Your idea is nice, but wouldn’t work actually, for multiple reasons.
For the 1st reason being that it’s not necessary.
I’ve done the calculations, and asked the manufacturer, and a 25um layer radius wouldn’t affect the mechanical properties in any way.
Second reason being that plating such large thickness would not only be expensive, impractical, but also BAD, because doing such a thick layer(50um) would require multiple baths, and start introducing crystalline imperfections at over say 100um.
And you can’t actually plate Beryllium copper. Due to having different properties of metals in the solution, the metals will plate out selectively, and the properties we want will be completely wasted, and the spring would become toxic if ever sanded, unlike the current copper alloy.
Finally, starting with BeCu C17500 would result in worse mechanical properties than what I want, and plating BeCu C17530, which is impossible, would not help in any noticeable way, and would be a worse option anyway. And using a copper wire as the base would be a very bad idea for obvious reasons.
2. Would be nice, but would cost more and require additional manual labor.
Would help if it was gold plated.
TLDR: Plating copper(20-25um)+silver on a BeCu C17530 38% IACS spring is our current best bet without going for the experimental BeCu C17550 60% IACS that is stupidly and crazily expensive, and in small quantities now
In for 12 of the unicorn emitters.
I’m in for:
20 large 3.0 springs
20 small 3.0 springs
Thanks for offering these.
In for 10 of the SST-20’s.
Thx!
Wow! Some n00b came here O:) and broke the forum page layout because he forgot to limit que maximum width span of his picture.
Related to this, when using the Advanced Post Editor the way I do is to specify 100% for both dimensions (relates to aspect ratio) and then, in the advanced tab, for Style I set max-width: n% where n is the maximum relative span which should be set no larger than 100%.
The max-width thing option would be something nice if set in the forum code, so no more page layout messes.
By the way, what's the budget phosphor bronze IACS rating?
19% IACS.
Do you have my 3 SST-20 FD2 LEDs on your list (BLF Interest List for Silver Plated High Current Beryllium Copper Springs upgrade and 95+CRI SST20/LH351D LEDs! )? I don’t see me on your spreadsheet.
Budget phosphor bronze springs: 0,15-0,20$US/pcs
Mmm, what does that means? $0.15 each small phosphor bronze spring and $0.20 each big spring? I just see a “C54400” column in the spreadsheet table so…
Thanks DavidEF/BlueSwordM.
In which case i’d like to add another 10 large and 10 small v3 springs to my order, taking the total to 20 of each.
And can you add 5 GA3s if that’s an option please?
I don’t have the prices yet, since I haven’t yet received an answer from the manufacturer.
I’ll do 10 of the SST-20s.
We are at 481 LEDs!
We’ll probably reach 500 LEDs soon, and I’ll be able to order the LEDs probably Wednesday.
Please put me down for 10 SST20’s.
