Thanks mate, yeah it was about the only way I could do it without machines and retain most of the original machined button look.
This is why I was so dismayed when that wabbit appeared on the final prototype!
Funny, Iāve been looking at a 4mm x 1.3mm x 7mm rectangular green vial that I can get over here.
It would completely cover the tail switch hole but I also like it as is with the variable brightness due to the GITD backing the trit as I have it now. Decisions decisionsā¦
From the diagram I can see you in 8x7135 mode, get 3 times sustainable output, 900 lm, compared to the original FW3A 300lm. How do you explain this enormous improvement? How is it possible?
Bypassed springs, thicker LED wires, cleaned & tweaked contacts, Noctigon MCPCB, better thermal paste, the light set to 65Ā°C thermal limit, hand cooled & moving around, not standing alone untouched.
I have working mans hands so can take some abuse
Bearing in mind my sphere is not calibrated the output is close to what others have given for that level.
3x XP-L HI should give around that OTF lumens at 3A.
You may be referring to the stock light set up to 45Ā°C thermal limit?
The thermal limit setting and cooling are factors that will determine the sustained output.
A single XP-L HI v2 running at 1A /65Ā°C should give around 400lm.
No idea. Iām not familiar at all with that light. A quick look, itās pretty big so has a potential to hold brighter for longer.
Itās also not so much the mods but rather what temperature youāre comfortable holding, ambient temp, LEDs, driver etc.
All lights will become heat saturated at some point, obviously the more mass, cooler surroundings etc the longer that will take at a given wattage.
Do you think it would be possible to epoxy a magnet into the stock button or is it only really doable the way you did? I really would love to make mine magnetic once it arrives. If you think it would be possible, could you check the diameter of the inside so I could source a magnet?
The internal button cap cavity measurement is around 11.6mm x 1.25mm with the central post removed on my version but I donāt think that size magnet would work too well through the 0.6mm steel, maybe an 11mm x 2mm N52 would do there but using the original rubber boot would be a problem, you would need to play around with some thin silicone sheet to maintain some waterproofing and maybe make a new small nubbin to get the switch working nicelyā¦
The tail cap button is an awkward size, measuring 14.6mm x 0.35mm at the widest point (retaining lip)
The button part is then 13.88mm x 1.4mm.
So if you had maybe a 14mm x 0.5mm or 1mm magnet JB welded onto a 13mm x 1.5mm magnet that could work with some modification.
Best to file off the nickel coating and clean thoroughly the sides that youāre gluing too.
Something like this:
One good thing about the FW3A is the switch is so easy to access you can play around with different ideas no problem.
Thanks for the info! Thatās a pretty good idea to make the button out of magnets. I definitely want to maintain waterproofing. I love EDC lights that have a tail magnet though. I will play around once mine comes in, which might take a little while.
