[Review] MHVAST TS70 (Cree XHP70.2, 1x26650) - Outdoor Beamshots Added
Thank you so much for the tests! This seems to be a decent boost driver in this light. I am waiting to see how the Astrolux MF01 Mini turns out, then I’ll decide. This looks like a good light for extended walks at night.
Cheers man
This might relate to the last few posts, but I noticed that after using this flashlight for a bit anytime I try to use turbo it immediately steps down…is this because the battery is below 3.8 volts?
Yeap, the battery’s low voltage is probably why Turbo won’t engage.
(or it could be thermals).
How does this compare to a D4S?
I wish I could tell you, but I am missing a D4S :slight_smile:
At what temperature does thermal control work?
Unfortunately I don’t have a temperature probe but it might be time to get one :slight_smile:
In the mean time, maybe someone else can enlighten us!
Hi all. I have a simple question. If with Mhvast ts70 let’s say from MID i double click and go to turbo if i click once will it go back to MID or turn of the light. And if i longpress from turbo will it go low mid high or do something else.
Can’t remember :slight_smile: I will clarify it in a couple of hours, after I get back home
Thanks.this will be very helpful in my decision of buying the flashlight.
Okay here's how the modes work.
1. Mid > Double Tap > Turbo > Tap Mid > Tap > Off
2. Mid > Double Tap > Turbo > Long Press > Mid > Continue Pressing (button isn't held off) > High > Ultra High > Low > (Mode cycling)
Thanks a lot for the quick and informative answer . This is perfect UI. The flashlight earned my attention and i will get one.
Dear bilakos10,
I just registered here to saying thanks to you for this thread.
After many searches and finally decided to purchase this one :slight_smile:
God bless you
You are welcome :slight_smile: I am sure you will enjoy your new TS70 :slight_smile:
That’s awesome to hear iSalalah :smiley:
Wish you have a nice stay in our community!
I would also try to bypass the springs if possible.
Just got my flashlight today
That’s great news.
Did the flashlight live up to your expectations?
I’m at office now, will test it night, however for quality it is great, i want to say thanks to you
Hi. I have one question about the regulation of the output after 3.8V in wih you have measured 5.06A what in lumen is that i gues somewhere about 3000lm or i am in mistake.
Received this light yesterday. First impressions are good. have had fun playing with it. USB C charging is great.
