I never did, but outside it illuminated better than a fire and where places fires were not allowed. Carbon Monoxide from stoves kill idiots in their tent.
Black Diamond Moji colour can give you yellow orange and red. Not exactly what you’re describing but small and light.
The one moji lantern I reviewed had terrible PWM, as did the Streamlight Lantern. Unfortunately it’s a common flaw in lanterns.
Thanks for the input.
I have a low tent. I tried diffusers but then the light was too large and I would bang my head agains it. BAD.
I also tried tiny USB lights coupled with Folomov EDC C4. I can recommend that to backpackers as the weight is very low. I will keep using them. But the lights sometimes don’t register touch which makes the UI finicky and annoying.
I intend to buy a larger tent, a villa for 2. This would be Quechua 4.1 F&B. This tent has black interior. So it needs quite a lot of light. And shining at the wall….doesn’t seem like a good solution. So I’m looking after some upgrade.
LR30 looks really nice except for the price.
Zanflare T1 - I also think there’s a space for a BLF lantern of this style. Actually we could largely re-use the LT1 architecture. Make the central screw larger so it fits 18650 inside. Don’t really need to change anything else. Great beam, proven design, much smaller and lighter than LT1. But anyway - I would call it medium size / weight.
GoalZero - yeah, the weight of this one is low. Considering that it fits 18650 - the weight is awesome. But non replaceable 2600 mAh and no diffusion
60 LED UFO? Interesting, with this price I may get one later (though the cheapest I see is $6.06 shipped).
But what really got me very interested was that LED strip. I’d like to attach it to the tent semi-permanently so I don’t have to mount it every time I set the tent up. So it would have to survive folding. And it must be waterproof - I’m often on the move, stay 1 night at some place and move on to the next. If it’s raining - the tent is wet outside before I fold it and completely wet a when I’m done.
I have some decorative strip like this:
Low CRI but otherwise OK. Warm. I can use a powerbank (like Folomov EDC-C4) with it. The good thing is that I can place the connector anywhere I please, so I won’t have to stand up to turn the light off.
I’m afraid that folding and unfolding the tent will kill the strip though. We’ll see.
Thinking about future upgrades, I did a search on “CRI 5V LED strip” (as well as several similar searches).
On Aliexpress there’s 1 result. Seeing this Ali shows the results for “5V LED strip” instead and I fail to find the single high cri result among the flood of uninteresting products. The singular CRI result is not even on the first page.
OTOH on Alibaba there are many results with CRI at least 80.
Could you attach some magnets to the tent and the LED strip, so you could just click it into place when you set up and peel it off before you fold the tent? That would give you a way to roll the strip up gently and store it somewhere dry while you’re on the move.
They’re dirt cheap and have cool and warm lighting (no high CRI though, but I’m somewhat of a CRI snob, but I can’t complain). They aren’t waterproof though, but work a solid 10 hours on a 2400 mAh 18650.
I use a couple of these usb chainable lights for ouside tent lighting.
https://s.click.aliexpress.com/e/cphfuEGY
Replaced leds with 2700K optisolis. Basically just switch, resistor and parallel leds in series. Probably can connect a driver somewhere.
I have a couple of these
Page Not Found - Aliexpress.comThey’re dirt cheap and have cool and warm lighting (no high CRI though, but I’m somewhat of a CRI snob, but I can’t complain). They aren’t waterproof though, but work a solid 10 hours on a 2400 mAh 18650.
Actually as long as setup is quick (and it is in this case) I don’t need waterproofing. So this is good, thank you for sharing your recommendation.
Cool.
Good to know this option, it would be cool to upgrade to Optisolis one day.
Nice idea though not for me.
Magnets would reduce setup / teardown costs but these would nevertheless be high. Since most of my stays are just 1-night long, this is a big deal.
Now I’m used to hanging a light off a loop and it’s OK.
Permanently mounted string lights promise to cut this down further so for now I’m going to try that. If the lights don’t survive - I don’t care much as they are very cheap, I paid $1.60 for a 10m string. I see that the seller claims it’s IP65 and I actually believe that’s correct (except for the plug) as the whole thing is enameled.
The side LEDs on the new Nitecore LR50 might do the trick if you have a mech pocket in the ceiling?
I tried my cheap light string.
It worked very well, way better than I’d expect from $1.6 light, especially as lightweight as this.
Considering the lack of regulation, the 10m string was just right. Bright enough to see, not enough to read, not too bright in any case. Note that my tent is big and has black interior so it’s pretty much the worst case; I would recommend shorter strings for other tents.
Note that 10m was likely too much for my powerbank to handle (I use Folomov EDC C4), there’s a good chance that the strip was not running at full power. I see a similar strip consuming 8W over 10m which would amount to 1.6A. I don’t know what can C4 support at the max but it’s likely 1A.
It weights very little, mere 20g (without powerbank). The heaviest part is the USB plug and short thicker wire near it. I feel tempted to cut it shorter, should be easy 3g saving. May do it one day.
I didn’t measure runtime yet. And I don’t know if it will survive folding. I folded it with the tent and I’ll see if it comes out alive. This time and quite a few times in the future.
What are the options to get regulated output? Here I see a 20m string with remote control for $6. I’m not fully convinced to remote so I did a quick search and I see there are 5V inline dimmers as well.
Dreaming about the future:
Remote would be nice if I could wire 2 strings to a single powerbank, one for the sleeping are and the other for the vestibule and control them with a single remote. Would be nice with smartphone control as well, except that my phone battery runs out too fast when using BT…
Another good example for a tent light: https://www.amazon.com/Coghlans-0842-Micro-LED-Lantern/dp/B001AZHFGQ
@ Agro, thanks for the detail on your usage.
Some more experience with the light string.
2 more trips, it survives folding so far.
I love how cosy it is with the light on, I’m way more satisfied than I thought I would be.
I so wish that the powerbank and the string used Type C connector.
Now I have a power bank - Micro USB - converter - Type A - string. And having to orient both MicroUSB and Type A correctly is annoying.
I may switch to another converter, one that makes it impossible to plug wrong. It will make things slightly easier.
Got one issue though, I got a single dark night where the string wouldn’t turn on.
I was too tired to troubleshoot and the next day it was OK.
Some connectivity issus (I tried reconnecting several times)?
Some weird quirk of my Folomov flashlight-powerbank?
I don’t know, I need to troubleshoot it the next time it happens.
Go to Customer Reviews. The 2nd one is from a fellow in Russia who was unsatisfied and soldered in his own LED’s. Red is kind of useless for a light such as this, as it’s not all that useful as an emergency beacon. So he swapped in warm white LED’s. Looks really nice now. Wish he had a better write-up on it!
Interesting. It’s not hard to get some high CRI, warm 5730. But I still stand by the starry light of the string.
I’m surprised no one has recommended the Nitecore LR10 https://flashlight.nitecore.com/product/lr10.
This is a great little lantern if you are packing lite.
I have a couple of the Soshine CB2 versions of that light you pictured, (I also have a couple of that same AAA-powered version) its a rechargeable 1800mAh Lithium Ion powered version. (built in USB micro charging, warm-white LED tint, AliExpress seems to be the only place i seen them. They work ok, small compact, lightweight, couple hours run time on high, around 200 lumens, down shining & ideal for hanging in a tent. https://www.aliexpress.com/item/32814866531.html?spm=a2g0s.9042311.0.0.188b4c4dKyUW3K
Two Fenix CL25R’s, one inside the tent, and the other in red mode. Zanflare T1 on low. I leave the red on all night outside. Works as a night light and doesn’t attract bugs.
No kidding? Dang. I’ve had one of these and got rid of it because step-thru UI was tiresome and basically forced you to use the light since it just blinded you. Had red though.
https://www.fasttech.com/products/3720601
Also had ordered this one, great battery life, USB recharge, no PWM, tiny, but does have the step-thru UI so cover it up for the first 3 clicks. Kept it because of size and battery life.
https://www.fasttech.com/p/3720501 D’oh!
I guess the mosquitoes will find me even in the dark but if red will keep away the dorks of the bug world, the Junebug, then I’m all in.
