Led4power.com : LD-4 CC linear drivers, ILC-0/1 illuminated tailcaps, optics, MOSX, copper DTP MCPCBs...
Well. Neven is here much longer and most of us know him well so we have a reason to believe more him than a new user.
Just my opinion.
You guys missed his (Mark Piezo’s) response to the butt hurt comment yesterday about duck and mouth, which was taken down right away.
Don’t feed the ducks! :laughing:
Throwing your toys out of the cot again? LOL
BLF Rules:
BY REGISTERING AN ACCOUNT YOU ALREADY IMPLICITLY AGREED TO ABIDE BY THESE RULES:
  1. Please don't be rude. Rude people will have their accounts deleted.
  2. Please don't use dirty language, please don't swear, and please avoid lewd or risqué conversations.
  3. Please avoid controversial or divisive subjects such as religion and politics.
  4. Please avoid fighting. If you or somebody else is losing their calm, please drop the subject.
  5. Please don't even think about spamming this forum. Spammers will be prosecuted.
  6. Please don't even think about using this forum for illegal activities. Criminals will be prosecuted.
  7. By registering an account, you agree to the BudgetLightForum.com Privacy Policy.
  8. All opinions expressed by users of this website may or may not be accurate, and as such BudgetLightForum.com does not officially endorse them. BudgetLightForum.com does not encourage risky behavior, and will not be responsible for physical, emotional, financial or other damages resulting from the use or misuse of any information or misinformation expressed herein. All users are encouraged to use good judgement before making any physical, financial or other decisions based on the information or misinformation expressed on BudgetLightForum.com.
  9. Have fun.
[quote=budgetlightforum.com/node/39504]
So, how to handle trolls? Two simple points:
Please do NOT respond to them in any way, either publicly or by private message.
Please DO contact me immediately.
It's that simple. Trolls do what they do because they are immature and like to get a reaction out of people. They will never change their ways if somebody with good intentions tries to counsel them. And they will get even worse if other users fight with them or insult them back. So, please try to use self control, and do not respond in any way, shape, or form.
[/quote]
Also, please do not quote other users' posts that violate the rules. Please go back and edit / delete your posts that quoted or replied to the recent outburst in this thread.
Thanks.
Is that the 1mm2 version of the Boost HX?
NM1 stands for for 1mm2 if following the White Flat nomenclature.
Yes, boost series have 4040 case, that's the easiest way to recognize it.
Hi Neven, can your drivers be set to one brightness level and used with a forward clicky switch?
There is one mode (100%) option in config. mode.
I use 3 lights with L4P drivers & FC switch (config: moonlight + 3 modes, no memory). All work fine!
Thanks!
And don’t forget you have the option of running that 100% mode as either the maximum controlled current mode or direct drive :slight_smile:
Sweet!
Zdravo Neven,
Apparently, the Osram HX Boost (4040 footprint) is not compatible with the MosX board. Is there any triple or quad MCPCB out yet to use with this LED?
https://led4power.com/product/mosled-extreme-mosx-ceramic-insulation-3xp-3535-triple-mcpcb-20mm/
Hvala vam! :-)
Pozdrav, Thomas
There is BLF Q8 PCB quad:
https://led4power.com/product/4x-osram-kw-culnm1-tg-1mm2-die-38mm-blf-q8-copper-dtp-mcpcb/
Yes, I have seen it and I feel tempted to buy it. :-) But do you plan to offer triple/quad MCPCBs for Osram Boost HX (CULNM1.TG and CULPM1.TG) with 17-20mm that fit into smaller lights?
4040 footprint is too big for 20mm triple and quad, I will have 3x/4x 3030 for white flats in 20mm in near future, they have almost the same (good enough) output till 4-5Amp per LED.
Clearance sale on some of DTP copper boards:
16mm XP/3535 CuDTP
0.5€/pc
20mm XP/3535 CuDTP
0.6€/pc
20mm XM/5050 CuDTP
0.6€/pc
BLF Q8 38mm 4x 4040/5050 CuDTP
2.97€/pc
I just noticed my jetbeam jet II MK has a centering ring that fits slightly loose for 3535 emitters. It might work perfectly for the 4040 without any modifications.
Do you think I need to regulate my output current to a safe level when used with a high drain 16340? Vapcell rates these at 6A but I don’t want to mess up a $10 emitter.
