W30 White Laser Flashlight Throwing 2408 Meters
Here ACEBEAM W30 BLOS (Beyond-Line-Of-Sight) white laser light comes for you. This unique illuminator generates a high concentrated single output of 500 lumens beam, and its beam can reach remarkable beam distance of 2408 meters away. The high-drain 21700 5100mAh USB rechargeable battery provides a runtime of 1 hour 45 minutes. The convenient USB charging function allows to charge the battery timely. An 18650 battery adapter is also included for wider battery options. The battery indicator tells the battery voltage status at any time any where. The included Red filter adds to versatility of the W30. Moreover, W30 can be used as a diving light with a depth under water 100 meters.
ACEBEAM W30 MORE FEATURES “:W30 White Laser Lights|AceBeam® Official Store | Flashlights, Tactical Lights
When will you produce a zoomie?
We will produce zoomie light in the near feature.
A LEP zoomie? :slight_smile:
YES!
What is the beam intensity of the 4000K and the >90CRI version?
So, does it come with a tripod and telescope, to hold the light still, and see the target 1.5 miles away?
wle
It does illuminate stuff closer by as well :wink:
I think that the beam is not that different from the BLF GT, illuminating a smaller area (about 5 times smaller in area) a bit brighter, but I still think it can be a useful illumination. I have seen the illumination that the Maxabeam gives (up to 12 Mcd), even that one can be applied as a useful beam without telescopes and such.
just saying
if the beam angle is smaller than the angular resolution of the eye, then - well i have lasers already - they are pretty bad flashlights ! :slight_smile:
Any sightings of :slight_smile: Price?
Looks fantastic. Also interested in specs for the high CRI and 4000K varieties.
MSRP $286.30. W30 White Laser Lights|AceBeam® Official Store | Flashlights, Tactical Lights
The angular resolution of a healthy human eye is about 30cm at a km, we are not there yet :slight_smile:
HKE has a price of 259$
So is this laser as in “Light Amplification by Stimulated Emission of Radiation” or is it laser as in “tactical teeny weenie narrow spot flashlight”?
It's a laser phosphor system using a real blue laser.
lenght 119,1 mm ? probably a mistake in the specification
Lasers have speckle and are also monochromatic which makes them very bad for illumination.
This is not just a laser, it is laser phosphor, basically a higher intensity LED with a laser diode instead of a regular blue diode.
It is laser pumped phosphor.
What would be the situation where someone need a >90 CRI laser?
It’s not a CRI90 laser, the laser used here has negative CRI. It’s CRI90 phosphor.
And this item is not a laser. It is a flashlight.
