I need to build or buy one of these triples in 5000K with 90+ CRI for picture taking. I have one in 4000K 90 CRI already, but that’s not good enough. Thanks for any help.
You might get better results with 5000K LH351Ds for that application. They have a bit more even tint and typically aren’t as green as 5000K 219Cs. They also have higher output, but less throw. They’re available (with free overnight shipping) from Arrow
You’ll need to reflow a triple board yourself though, as they don’t come mounted.
Hmm Virence has lots of choices, but i’m afraid I don’t understand my options very well. I am using a variable power supply and a CPU heatsink. So voltage and cooling are no limitation. I just need lots of brightness, 5000K, ultra great CRI, and no hot-spot. That’s all
Yes that is the quad E21A arranged like a quad core emitter (e.g. : Cree XHP-35) which you can use with an OP reflector ot TIR optic. There is also a quad Optisolis for Carclo Quad (106xx series).
But about four months ago I asked Clemence if he would willing to make a triple and/or quad E21A for Carclo Triple and/or Carclo Quad. He is going to make this triple, but only when he will finish his city big project.
If you want really high output on a budget and can go bit above 5000K, a member has 5700K, 100W COB’s for sale here:
$16.50 shipped price for ~10,000 lumens that Maukka has verified at roughly 95 CRI and high R9. You will need at least a 30V power supply. Optic choices will be limited, but it can be used as a pure flood source, or with barn doors.
100W might be a bit beyond the reasonable heat shedding capacity of the standard Intel stock cooler.
It will have a slight green tint, similar to typical LH351D or Nichia 219C emitters. White balance should be able to take care of that in most situations.
If you want something that can be used with a readily available optic such as a Carclo triple or quad, the LH351D is probably the best price option.
I believe the XHP-35 produces a bit of a beam even when used in open air, and I have never seen them reveal their CRI R9 rating, so that’s always a bad sign. Maybe someone knows better than me?
