I read on reddit that the D4 should be soon available in the same sand color of the D18! Is this true? I wish he also add a knurling on the tube like the titanium version.
Aye. I would love Green or Titanium, but sadly I missed my chance for either of those options.
As the new D4 has flashing pads on the driver, will there be an adapter available, or will I have to get creative with some modelling clay and bare wires? After trying the improved 6/02 version of Anduril, I simply must have it on my flashlight.
It looks like you got one with a 2019-05-21 build, but I think the D4 should mainly ship with a 2019-06-05 version instead.
Muggle mode has been removed at Hank’s request. It seems to cause too much confusion. I’m kind of happy to have it taken out, TBH.
I’m hoping Hank or someone will make the pogo pin adapters commercially available, but I don’t know what will happen.
It’ll definitely be required for the Anduril version of the D4 though. It seems those are using a new tiny1634 driver, so the pogo pin adapter is the only way to flash it. A SOIC8 clip won’t work.
The RampingIOS version is still tiny85 though. That code hasn’t been updated to run on tiny1634. So if anyone wants to make sure they get tiny85, order the RampingIOS version.
Tiny85 and tiny1634 are not binary-compatible, so a .hex for one doesn’t work on the other.
The new chip is a significant improvement in some ways. It has twice as much space for code, and it has quite a few more pins available for inputs and outputs. Past designs have often been rather limited because there weren’t enough pins, and that restriction mostly disappears with t1634.
Nice!!! Sounds like it’s time for your to start writing firmware to take advantage of the new chip TK!!!
So what new features are you going to add support for to take advantage of the extra space and pins?
Some suggestions:
Support for a speaker - so when we enter lightning storm mode in Anduril the light will play the sounds of simulated thunder with each lightning flash.
Support for a sprinkler - Why just limit lightning storm mode to the sounds and sights lightning? The light should also provide rain so we get the full experience!
A calendar - so the light can sing us Happy Birthday on our Birthday (using the previously referenced speaker)!
An accelerometer - so the light can detect when it’s been dropped and then tell us so through the speaker. I’m sure we’d all like to hear our light yell out “OUCH! WATCH IT DOOFUS!!!” when we drop it.
Support for robotic legs - Why change the battery manually when our light can just sprout legs walk over to the charger and change the battery itself?
You joke, but I’d actually like to add sound and an accelerometer. What I have in mind won’t fit on an attiny though… it’ll need something more like a raspberry pi zero. I’m hoping to eventually make a lightsaber driver which synthesizes its sounds on the fly, using an accelerometer (among other things) as one of the inputs to the synth engine. The lighting would be tied into the same engine too, so sound and light are generated in sync and both would be personalized for the individual person using it.
Also hoping I can fit a contact mic in there somewhere, attached to the blade, so it’ll incorporate the sound of whatever it hits. This method is used on the Korg Wavedrum, and it works surprisingly well. That might be a bit ambitious though.
In the short term, more pins and more space means we can do things like a 7+1+7+1 driver on the next lantern, for adjustable color temperature with more fine-grained brightness control. Or a dual-constant-current driver, like two of what the BLF GT uses. Also, maybe the ability to have more than one switch, have both a flood and throw LED, or more than one aux LED channel, or … whatever.
The tricky part will be incorporating all that into FSM, and into Anduril, at the same time. Keeping the code and the interfaces clean will probably require some refactoring.
Just got my emisar d4 xpl 3A with Anduril from Hank! Man, this thing is a light weapon. Lol!
Quick question. I’m assuming it’s normal that there’s like a little “notch” in the ramping. I’m assuming it’s just as it switches from regulation to FET? Or it’s just an anomaly because the firmware is expecting 3 7135 in the d18 as opposed to one 7135 in the D4?
you nailed it, the “flicker” is the transition from linear regulation via the 7135 to PWM via the FET. Or maybe better put, there is also PWM with the 7135 until it gets to 100% duty. That’s when you will get the flicker. Higher outputs add PWM via the FET to the 100% duty 7135 current (nominally 0.35A IIRC).
Okay, done playing with it for now. The D4 has pretty much rendered all my other flashlights pointless. Lol! My custom Convoy M2 with FET driver and MGT2 got its ass whooped!
I really dig the candle and lightning modes!
Seems to like my LG HG2 more than my efest purple 18350. not surprising.
I have some pocket clips that work but I think I like it au natural. Haha.
