Actually, I came up with this idea a moment ago. I have never tried to use it.
Whenever I had a problem with pulling out the optics, I used a small screwdriver or thin blade (when it was cramped) and undermined a bit at each leg.
I tried this before and I couldn’t pull it off without damaging the optic. I mean it’s pretty tight between the optic and shell, you can’t really stick something in between it without damaging either the optic or shell.
I’ve tried this as well, not sticky enough… The only time I’ve been able to cleanly remove the optic is when the optic loosely fits in the shell (depending on the make of the shell) and it comes out due to gravity from having the dropin upside down.
In the future, I was thinking about putting slots on the edge of the optics so that I can use the slots to pull out the optics. I’m not sure if that will effect the beam but I’m guessing it won’t since I won’t touch the TIRs.
Dunno if you have access to ’em, but if you pinch each leg (2 simultaneously) between thumb and forefinger, the sides of your fingers can spread ’em apart like a soft wedge. Rotate 1-2, 1-3, 2-3, etc. a few times each ’til it pops off.
I’ve tried double sided tape, foam and thin. The tape comes off of the optic and won’t stick. Has anyone had the same problem and have a tried and true method of taking out optics that are hard to pull out? I have tried a bunch of different sticky tapes and suction items to pull off the optic but to no avail.
There is plety of room inside legs. Can drill&tap holes, drive screws inside and pull it out.
After you will have optics almost ready for tritium (or ruined one).
P.S. Most 10507s have pin going out of main radius border. Probably it is too tight because of this pin. Try to cut this edge with razor blade.
Yeah, I was trying to see if anyone had any other special tricks. I don’t have another optic lying around but I guess I’ll just have to order some.
I wanted to point out, if I don’t press fit the optic into the shell then there will be a gap between the optic and leds, and the beam will be affected. Also, by the pressure of the head/bezel of the flashlight, the main spring, and battery the optic will be pushed into the p60 shell. So there’s no real way to avoid it.
I don’t have the skills to drill the legs without messing it up. However, in the future I’ll try cutting the pin you are referring to but I think I’ll just cut a slots at the edge of the optic so I can use tweezers/small flat head to pull the optic.
Drilling the legs seems easy so i wonder if you’ve misunderstood the instruction? You gently drill down into the leg (or all three legs) a couple of millimetres with a thin drill bit then screw in a similar sized self-tapping screw. It only needs to go in a couple of turns to give you something to pull on.
I know drilling seems easy but when it comes to smaller components I can be klutzy. So easy to some, not necessarily easy to me. I can probably use a triple mcpb as a guide to help and I might actually try this but it’s definitely not “easy” to me and I have a high chance of screwing it up. However, I might end up trying this if I can’t figure any other way to remove the optic.
That’s fair enough, we all have different abilities (and tools :D), i picked up on the fact that you’re comfortable cutting a slot in the side of the optic which i wouldn’t have a clue how to do so just wanted to check you understood the suggestion, which you do
