[Excellent tester, comes in the case. Control occurs with 4 buttons. On both sides of the type-c socket, there is also a microusb input. Automatic qc protocol testing menu Long press the right button input to the menu. Left button input under menu It is possible to connect the tc66 tester to the computer. To connect, you will need a microusb cable. Well, the most interesting, you can download the program to your phone, and connect via bluetooth. The tester is excellent, i advise!]
product link:[Click Here]
another review(Thank you for your support)
[Technology with a type-c connector becomes more and more, so this tester was so necessary for me) with it i can check the capacity of the charge of the superbanks, track the characteristics of the charge technology and output via bluetooth all this on the phone screen, check the wires for conductivity and evaluate the charge protocols. I like the product the ability to trigger quick charging protocols: it is immediately visible that it supports charging and where the sagging occurs. The tester is miniature, which is convenient. The small screen displays many functions of charge, characteristics of current, voltage and capacity. Purchase is satisfied! I advise the seller. Delivery took 9 days. The tester is suitable for everyone who wants to be aware of the quality of the cords used and, most importantly, check the supported protocols in the adapters for lice.]
new review(from Japan)
“Meanwhile, RD TC66C of the new product also supports measurement of USB PD 100W at a low price of $ 24.50, and also supports trigger functions such as USB PD, Quick Charge, and FCP. In addition, it is possible to connect to a USB cable and see the current and voltage with a PC, as well as to confirm with a Bluetooth connection and a smartphone application.”
quoted from “”click here”“:RD TC66Cレビュー。USB Type-Cポートに直接挿せるPD 100W対応万能テスター - AndroPlus
product link: https://www.aliexpress.com/item/32968303350.html
these days we have uploaded many daily work video on YouTube, including repairing videos and inventing video,if you are interested in making power supply or repairing them,you can have a look at these videos.
new share
NEW SHARE:
[Ordered 12.05, received 01.06.209 (21 days to kiev, acceptable) with delivery meest express. And then, the adventures began with delays, handed over to some “rosan”, he transferred to the usual post office at the place of residence, as a result, took in the mail only on june 10, t. e. It was only 300 days. The tester, very well packed in a sealed gold chinese seal :-)) branded plastic box with soft tabs, in turn, was placed in a foam box of two halves, t. e., to damage it would be difficult with any transport shipments. Turned on-works, high-quality color display, then we will test more in-depth. It is convenient that the link to download the user manual (in english and chinese) and software is indicated on the product page, very well and fully decorated and on the liner in a box with a tester! Good firm, good store-i recommend to everyone!] cilck me to view TC66C
TODAY’S SHARE
[Let’s look at the technical capabilities of the device. The coolest thing is that there is normal pd support (bidirectional), and the app for the smartphone. And most importantly, there are triggers. Can manually activate the output voltage of 9 v/12 v/15 v/20 v for qc and pd devices. This tester allows you to measure very accurately the capacity for example a poverbank with type-c output, because it measures voltage from 0 to 30 volts. Limit current measurement 5 amps. Resolution of as many as 6 digits: for measuring voltage 0.00001 v, and for current 0.00001 a. In addition, independent power via micro usb port. And a great opportunity, you can measure the power not only from the charger, but also back-from the type-c port of the smartphone or tablet. In this model of the tester, it is possible to update the firmware, this is undoubtedly a plus. The tester allows you to see the protocol used and switch it to another if it supports the power adapter In general, the tester perfectly copes with its functions.] https://www.aliexpress.com/item/32968303350.html
