Ok I felt bad for poopooāing on the knurling without offering better feedback. Hereās a few minutes on a belt grinder. The mid section is clean looking and smooth now and I left the head as is for better grip. IMO, this feels and looks much better to me.
Anyone tried this with 10440 li-ion cells? Besides Noctiluco, that is.
Noctiluco said, in a related Sofirn C01S 4000K 100 lĆŗmenes thread at ForoLinternas, the torch becomes a lot brighter and works fine with li-ion. But he only tested the thing with protected Turdfire cells, this is the reason I am asking for further feedback. Does the C01S implements low voltage warning or cut-off for 10440s?
I have one C01S that I used for crash-testing, works fine but looks crap now. I will try one of the new Vapcell 10440 cells in it (seems more high drain even than the Efest 10440) and see what happens :smiling_imp:
Be wary of the low voltage cut-off thing, set a li-ion charger at hand djozz.
I wonder how does the thing work with higher voltage cells. āDDā with sense resistor limiter like in cheap SK98s? Did someone dissected its driver yet?
I have no idea, but since I started this hobby, the many cheap AA and AAA flashlights that i had either burned with a li-ion, or work well but never work again in boost modus, or keep working fine with either cells. I do not think the typical boost driver for AA and AAA cells are specifically designed to function with Li-ion cells but it is simply a side-effect of the circuitry.
So the 10440 gave surprisingly a lower output than an Eneloop. It appeared that both the tail spring had collapsed, breaking contact, and that the driver stopped working as boost driver: lengthening the spring made the 10440 work again but not the Eneloop. One component on the driver, on the left, showed a tell-taling bulge:
Note that thereās no easily identifyable boost coil.
Inductors (coils) come in chip-style packages that look very much like a SMD capacitor. Iām not so sure what those two components are towards the bottom: the reddish thing and the sparkly looking one. One of those might be the inductor. Granted, there are coil-less ways to boost voltage (eg, charge-pump) but I doubt thatās what weāre looking at.
Wellp, the red thing seems to be a 47ĀµF tantalum capacitor. Thus, the grey/silver finish sparkly looking thing must be the (tiny!) inductor.
If that is the driver inside current C01S flashlights, how can Noctiluco say his C01S works good on 10440 li-ion cells? May someone give an explanation?
Could it be because he is using protected Turdfire 10440s? :-D
Sorry to read that djozz :zipper_mouth_face: I was thinking it could survive butā¦not :zipper_mouth_face: So only Ni-MH and alkalines on this one! And it will do the job for sure
i disagree - i think the cells are cute and deadly in short bursts i dont mind them at all. only shame is the super low capacity lol :person_facepalming:
